Results 1 to 10 of 13
Thread: Switch button ?
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Angry Switch button ?
    I have tried every thing to swap gotofirst and gotolast on the same button
    "GOTOFIRST;SWITCHBUTTON;2" - "GOTOLAST;SWITCHBUTTON;1"
    "GOTOLAST||SWITCHBUTTON;1"
    "GOTOFIRST>>GOTOLAST"
    Help
    2001 S10 ZR2
    Chucks Skin - to old
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The Button number is relative to the position of the B line in the file.. make the button with this code: "GOTOFIRST||SWITCHBUTTON;1>>GOTOLAST||SWITCHBUTTON ;1" the first 'Bxx' line of the .skin file.
    Ride Runner RR's Myspace
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Thanks guino it work like a champ
    2001 S10 ZR2
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Now this is one for guino
    I am trying to make a button for xm stop (mute), play (unmute) and have a lable on the button that says stop when unmuted and play when muted by using switchbutton and switchlable at the same time.
    Is this possible?
    2001 S10 ZR2
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Button Code:
    "PAUSE||SETLABEL;!MYMUTE;Play||SWITCHBUTTON;1>>RES UME||SETLABEL;!MYMUTE;Stop||SWITCHBUTTON;1"
    Label code:
    "!MYMUTE","Stop"
    Apparently I don't have setlabel in the .txt either..
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Thank guino
    Set label is in the .txt file but I would not have known to use it much less figured it out with switch button.
    This is what I ended up doing
    Button Code:
    "PAUSE||SETLABEL;!MYMUTE;||SETLABEL;!MYMUTE2;Play| |SWITCHBUTTON;1>>RESUME||SETLABEL;!MYMUTE;Stop||SE TLABEL;!MYMUTE2;||SWITCHBUTTON;1"
    Label code:
    "!MYMUTE","Stop"
    "!MYMUTE2","
    By the way when you put the text in the label code caps will not work but after setlabel changes the label caps work.
    2001 S10 ZR2
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I guess if you're using 2 labels it would allow you choose font and color separately for displaying Play or Stop...
    What do you mean by "caps will not work" ?
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    When the skin first opens all the letters are in lower case till the button changes the labels even if you have all capital letters in the Label code: as in my stop above.
    2001 S10 ZR2
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    This morning I loaded this skin in to the truck computer and pause and resume did not seem to work in XM. Is this true and should I use mute instead or is it just the version of rr I have?
    2001 S10 ZR2
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't think Pause/Resume work propperly with XM (I seem to remember a bug where it seems they are inverted..) I have to fix it.. but earlier versions may not even have it implemented.
  1. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 10:48 PM
  2. Capture GPS data at the flip of a switch
    By Mr. Inquisitive in forum GPS
    Last Post: 02-02-2005, 06:06 PM
  3. I want my pc to come on with a toggle switch
    By muldrick in forum Power Supplies
    Last Post: 07-04-2004, 10:10 AM
  4. Installing On/Off Switch with Opus 90W
    By Judgement in forum Power Supplies
    Last Post: 07-02-2004, 01:43 AM
  5. Need clairification on wiring on/off switch
    By syclone477 in forum Newbie
    Last Post: 03-23-2004, 04:59 PM
