Results 1 to 6 of 6
Thread: Mixer Fader
    Jul 2005
    Mixer Fader
    I don't know if this is alrady been talked about but i know you have the Bal, Bass Treb in there but if i use a via mobo with a pcmcia card slot and the creative audio card i would like to use a 4.1 setup on the amps in the car so in adition to bal i would need fad, and sub. is there any way you can do this.
    ps i would like to remove the cd deck all the way due to room issues that is why i ask.( and yes i know i could setup the settings in windows first and then just use road runner.)
    JC
    Work in progress
    Via mobo
    512mb ram
    80gb hard drive
    7in touch screen
    opus 120w psu
    gps bu-303
    dvd-cdrw slim
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can make buttons to control ANY line on the DEFAULT sound card (Set in control panel).. read Skin Commands.txt to know how.. I am still working on adding support to sliders to control ANY audio line on the DEFAULT sound card.
    Ride Runner RR's Myspace
    Jul 2005
    Thanks quick response.
    Work in progress
    Via mobo
    512mb ram
    80gb hard drive
    7in touch screen
    opus 120w psu
    gps bu-303
    dvd-cdrw slim
    Constant Bitrate accentsound's Avatar
    Jun 2005
    Jupiter!!!!!! FL.
    Just remember the audio driver mixer has to have the control sliders in the first place. Many do not have sliders for front rear fade or independent control for Sub Out
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by accentsound
    This is a good point.. and that's the reason why the Mixer on the Brushed skins has sliders for the "most common" types of mixer controls.. I am adding support to control any audio line (by specifying the name of the audio line) but you'll likely have to tweak it for your specific sound card. This will be done by the NAME of the audio line simply because there are many audio lines that can't be identified by any standard mixer functions.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    See here I go again.. I had already added support for the custom Sliders.. even BEFORE the latest BETA versions.. just forgot about it and about documenting it... basically you can make a slider with codes like these:
    "VOL;Wave" -- "VOL;Front" -- "VOL;Rear" etc... just specify the audio line NAME and you should be good to go.. You can look up the names of the audio lines using the windows mixer or look at the debug log file... I'll add it to the documentation for next release..
  1. RR 03-11-05.. Mixer Presets ...
    By guino in forum Road Runner
    Last Post: 03-12-2005, 12:46 AM
  2. 5.1 ch external usb soundcard causes error in mixer.
    By fasternfaster in forum MediaCar
    Last Post: 09-28-2004, 03:20 PM
  3. Mixer settings in Mediacar Vs. EQ on HU
    By fly_dutchie in forum Car Audio
    Last Post: 07-21-2004, 12:54 AM
  4. Just basic treble/bass controls thru mixer API?
    By OrangePeel in forum Media Engine
    Last Post: 05-30-2004, 07:08 AM
  5. can i use any sound mixer on ME2?
    By iPal in forum ME Archive
    Last Post: 11-10-2003, 10:15 AM
