Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Phoco and RR (again)
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    <PhoneControl.NET>1.4.5.29756<BatteryStatus value="70" /><SignalQuality value="3
    This could be the problem right here.. seems that Phoco is creating incomplete messages there.. the signal quality tag is incomplete and there's no </phonecontrol.net> tag.. unless you cut the data yourself, this would prevent RR from parsing those messages.. is that the latest Phoco ?
    Ride Runner RR's Myspace
  2. #12
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Sorry Hyperterminal seems to write over the end of the line when it has wrapped it with the next line.
    here is the correct line
    Code:
    <PhoneControl.NET>1.4.5.29756<BatteryStatus value="50" /><SignalQuality value="3
    1" bars="6"/></PhoneControl.NET>
    version is in the line above
  3. #13
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Just tried sending a command from Hyperterminal to dial a number
    Code:
    <PhoneControl.NET>
    <Dial number="07788414287"/>
    </PhoneControl.NET>
    and it worked fine.
    Definitely seems to be a problem with RR not able to connect to Phoco through the port.
  4. #14
    guino's Avatar
    Nov 2004
    Toronto, Canada
    What port are you using in hyperterminal ? also, I hope Hyperterminal is CLOSED when you're trying to use RR.
  5. #15
  6. #16
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Is there a way of testing the input/output of RR like there is with phoco (ie hyperterminal or something)?
  7. #17
    Dec 2003
    Germany
    Well I think you can just log in the PhoCoLog.txt and see what RR send if I am not totally mistaken
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
  8. #18
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by Jeeve5
    there is nothing in the phocolog from RR.
  9. #19
    Dec 2003
    Germany
    There should be else RR and PhoCo are not working toegether properly!
    BTW, on a sidenote: The PhoCoLog.txt gets replaced everytime PghoCo starts! Just FYI incase you didnt know
  1. WANTED: Phoco BETA testers for RR...
    By guino in forum Road Runner
    Last Post: 12-05-2005, 10:05 AM
  2. phoCo remote control w RR??
    By liquid_smoke in forum Road Runner
    Last Post: 08-01-2005, 01:42 AM
  3. RR -Phoco bug
    By mauri in forum RR Bug Tracker
    Last Post: 05-30-2005, 02:27 PM
  4. RR & PhoCo launch
    By BMVEE in forum Road Runner
    Last Post: 04-24-2005, 11:06 PM
  5. RR 04-19-05.. Improved Phoco..
    Last Post: 04-20-2005, 10:38 PM
