Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 47
Thread: RR and I-Bus version 2.0 beta
  1. #31
  2. #32
    Feb 2006
    Ibus hibernation issues...
    issue resolved...
  3. #33
    FLAC sama's Avatar
    Feb 2006
    London, UK
    what were the issues and how did you resolve them?
  4. #34
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by E46M3 View Post
    iI've read and searched and have been redirected to this post but i still cannot resolve the hibernation issue i have...
    if someone can help me or send me a working file version it would be greatly appreciated...
    *Problem:*
    Ibus runs perfectly fine with the file that CDR have created.
    However, after hibernation and teh system tries to restart back up the system hangs and does not start back up. I have to manually turn teh system off and then turn it back on.
    I am also using RR version 6/03/06
    The newest version has too many bugs that i can;t seem to overcome..
    Also using Lloyd's simplistque skin.
    Don't know what his solution was.
  5. #35
    Mar 2005
    Quote Originally Posted by JohnMP3 View Post
    I know what causes this error. I spent nearly 6 hours figuring it out - I even had to debug the application. Normally this is a mismatch between windows language settings. In this case, it is an extra LETTER in your ibuscomm.ini file. Check it and find the extra letter or character outside of the quotes. That or restore to another default ini file. That will fix the problem.
    Hi,
    Thanks for finding the error. I am a bit confused though, do you mean i have to search the entire .ini file for the extra character?
    couldnt you please just tell us where that "extra LETTER" is?
    Thank You
  6. #36
    Constant Bitrate jeep642's Avatar
    Sep 2006
    Chevy Chase, MD
    *Problem:*
    I have a problem coming back from hibernation too.
    I thought it was the iBus...wasnīt...was my sirius module...
    Anyhow, if anything (preferably USB) is preventing your machine to come back from hibernation, DEVCON is what you need, check out this thread by V8 Scimitar. Heīs guiding you through the process of setting up your computer to disable before hibernation and enable after hibernation any USB device that could jam this process.... just awesome!!!
    hope itīll help
    cheers
    _____________________________________________
    If you made your own skin, visit
    The CAR PC NETWORK SKIN PAGE
    at the
    CAR PC NETWORK
  7. #37
    Oct 2005
    Raleigh, NC
    Send I-Bus messages via keyboard?
    Hi all,
    Is there any way to map keyboard strokes (e.g. F1, F2 etc) to CdR's modified IBUSComm.exe, and have the PC send the specific I-Bus commands to the I-Bus?
    Within CdR's GUI, I can send commands via the drop down menu, but am looking for a way to map this to specific keyboard strokes.
    Something like an ini file would be great!
    Thank you,
    RRG
  8. #38
  9. #39
    Oct 2005
    Raleigh, NC
    KeyTBL.ini is an interesting approach. Does it support the ability to map keyboard commands and send I-Bus messages? I understand KeyTBL.ini's ability to send RR commands, but for my experiment, I need to send I-Bus messages.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Look for a plugin called iBusRR that was setup up to allow control of windows and lights, I'm sure other commands can be added.
    Then it is a matter ao marrying the two (KeyTBL.ini, iBusRR) together.
