Page 1 of 5 12345 LastLast
Results 1 to 10 of 47
Thread: RR and I-Bus version 2.0 beta
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    This is long overdue.. sorry its taken so long. I couldnt find the source for the 1st version.. so just re did another one. I have added hibernation to this one.. I have put a 5 sec delay when coming back out of hibernation, let me know if this is long enough
    You can still alter the buttons at the bottom of the .ini file to what you want. I have preset them as following
    [ID:STW_PREV_PRES]
    MsgTemplate="5004683B080F"
    Label="S. Wheel < Press"
    Parse=True
    KeyboardMap="RRPREV"
    [ID:STW_NEXT_PRES]
    MsgTemplate="5004683B0106"
    Label="S. Wheel > Press"
    Parse=True
    KeyboardMap="RRNEXT"
    [ID:STW_PLUS_PRES]
    MsgTemplate="50046832111F"
    Label="S. Wheel + Press"
    Parse=True
    KeyboardMap="VOL+"
    [ID:STW_MINUS_PRES]
    MsgTemplate="50046832101E"
    Label="S. Wheel - Press"
    Parse=True
    KeyboardMap="VOL-"
    [ID:STW_PHONE_PRES]
    MsgTemplate="5004C83B8027"
    Label="S. Wheel phone Press"
    Parse=True
    KeyboardMap="MUTE"
    [ID:STW_RT_PRES]
    MsgTemplate="5003C8019A"
    Parse=True
    KeyboardMap="PLAY"
    The KeyboardMap=" change here " is the command you need to enter. So if you wanted to change the MUTE button, so when you press it, it takes you make to the main menu, then the RR code for this is "MAIN". Check out the Skin commands text file thats in your RR folder for more command.
    have fun !
    CdR
    Attached Files Attached Files
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Nice. Now I only have to get my steering wheel to work the iBus.
    Oh yeah and fit the steering wheel to the car
    Feb 2004
    Manchester
    anyone confirm if this is working or not ?
    May 2005
    Germany
    Hello,
    Today I bought the same Interface as you have.
    I downloaded and get 2 files. What to do with this 2 files. Is something to change in RR to run it?
    Feb 2004
    Manchester
    hmm 46 downloads and no feedback.. kewl
    Low Bitrate lchatela's Avatar
    Aug 2005
    France Annecy
    I will try at the end of the week.
    Do I need simply to run the .exe and it's ok or do I need to put the file somewhere in RR?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by CdRsKuLL
    Still haven't got my steering wheel to work out of the car. Just got another will see if that works.
    May 2005
    Germany
    Would it be possible to have two commands for one button like:
    command1 : press
    command2 : press and hold for x seconds
    or ist the st-wheel only build for one command?
    Ti-ejtsch
    Constant Bitrate JPuma's Avatar
    Jul 2005
    NY
    First,
    Hey CDRskull, I going to give this some play. I alredy have IBUMCOMM working well but I will give this a shot. I am speaking to frank who created ibuscomm because i noticed a problem with the hold events. it works with button 1-6 as far as I can tell but if I try to use the hold event for the right turn knob it sends both events, the button push and the button hold. For some reason the ReleaseID command dosent work on the knob controls and I get an error when loading ibuscomm. Not sure if you have this working in your version of the program but it would be nice to have the right knob as "PLAY" and the right knob hold as {ESC} or "MAIN"
    This should be possible with the <> buttons on the obm and steering wheel since if you hold them theres another ibus message to fast foward and rewind insted of skip and back which is noramlly used to control the CD changer.
    Aug 2005
    Bangalore
    CDR - have this working in my car - worked first time around and its made a huge difference. thanks for posting this.
    the only very minor crib is that (i think) sometimes it sends double events (so skips two songs, or moves the volume two steps) - but that is a very minor issue.
