Page 3 of 8 FirstFirst 12345678 LastLast
Results 21 to 30 of 77
Thread: RR 08-02-05... SIRIUS Support ...
  1. #21
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Guino, could it work with using MM/FD's City? (could you add this option)
    like mybe you can add an option to make cityweather=FDCity and a countryweather=São Paulo, Brazil so it would get the city I'm in.... (and use São Paulo if it cant find weather for that city)
    Roy
    2005 Range Rover 4.4
  2. #22
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by RoyN
    This will be very useful
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
  3. #23
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by maestro83
    hi guino, thanks for the speed of your Update but I would have a problem, INDICATOR:"direction" does not work, or mistake I!
    you could help me?
    the logo flash it does not work, does not come more redesigned!
    Note: the indicator "DIRECTION" works only with MM (currently) -- I'll also parse FD messages in the future so it works with it.
    The most important thing is that the CURRENT SKIN has the MM_*.jpg images available for drawing. Otherwise it won't work.
    The flash logo works, but you're basically overwriting the area of the logo (and that was "granted" on previous version) -- but won't work from now on... you should either reduce the size of the flash logo OR make transparent OFF/DOWN and ON images to where it only draws the buttons outside the area used by the flash logo. To do that, you just have to make BMP files instead of JPG (lossy), and make the transparent area (where not to draw) PINK (Full Red, Full Blue, No Green).
    Ride Runner RR's Myspace
  4. #24
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by lostreception
    not sure if its only me but the "w0dayicons" etc dont load on my summary or main page
    As I posted on the notes: the WEATHER folder needs to go under RR's subfolder and NOT on the Skin's folder.
  5. #25
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Guino, could it work with using MM/FD's City? (could you add this option) like mybe you can add an option to make cityweather=FDCity and a countryweather=São Paulo, Brazil so it would get the city I'm in.... (and use São Paulo if it cant find weather for that city)
    I'm not done with the weather, and have actually devoted little time on it so far... I do intend to allow it to use the GPS's city info for weather... but there are many things I need to work on it..
  6. #26
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    As you mentioned above, the problem with the flash i'm using is that my ON image also uses the same area of the flash, the flash was transparent before.. but I will alter my skin now to suit
    cheers m8
    CdR
  7. #27
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by CdRsKuLL
    cheers m8
    CdR
    If anything, I can probably add some code to redraw the flash object when drawing over it, but chances are it might make it "flash" (literally)..
  8. #28
    Oct 2003
    Quote Originally Posted by guino
    I'm Thinking TimeTrax does the same (simulate a COM port).. MitchJS will make boards available for sale as soon as he's back from Vacation (mid-August).. but any adapter with a COM port in windows should work.
    Has he left yet? I know he had a few trials left, and I've been trying to get a hold of him for a few days, but he's not responding...
  9. #29
    Maximum Bitrate Chita79's Avatar
    Oct 2004
    San Diego, CA
    it would definately be nice to see timetrax embedded/reskinned into RR!
    '05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
  10. #30
    Newbie maestro83's Avatar
    Aug 2005
    Alessandria
    Exclamation
    original post: from guino
    I have understood thanks!
    for the logo all ok! for "direction" it does not work!
    I have inserted in skin the images mm_*.jpg, I have started MM but nothing!
  1. RR 06-06-05 .. Winamp Library Support ...
    By guino in forum Road Runner
    Last Post: 06-19-2005, 01:36 AM
  2. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 11:37 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
