Page 4 of 8 FirstFirst 12345678 LastLast
Results 31 to 40 of 77
Thread: RR 08-02-05... SIRIUS Support ...
  1. #31
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by maestro83
    I have understood thanks!
    for the logo all ok! for "direction" it does not work!
    I have inserted in skin the images mm_*.jpg, I have started MM but nothing!
    Does the ETA/ETR/Location etc info show propperly on the BMV2 skin ? If it doesn't you probably just don't have MM setup to interface with RR (Like the GPS FAQ says). I'll double check it later tonight but it was working when I tested it..
    Ride Runner RR's Myspace
  2. #32
    Hi guino,
    As always.. awesome job. Just wondering if you had a chance to look into the balance fading to one side on some Audigy soundcard? I had post this as a bug/request on you previous release. Appreciate if you would update me as whether you are going to add a lock function to the balance or not. Thanks
  3. #33
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sorry I forgot... I'll try to add an option to force the initial balance as soon as I have a chance..
  4. #34
    Newbie maestro83's Avatar
    Aug 2005
    Alessandria
    Quote Originally Posted by guino
    The ETA/ETR/Location etc info is come visualized!
    The setting of MM is corrected, perhaps mistake I!
    You could makes to see the rows me * skin where is "indicator" that it works?
    Thanks a lot
  5. #35
    Nov 2004
    Guino,
    Just a quick question, is there anyway to make RoadRunner tell you if it is connected or Disconnected to the Internet? I guess what I want is something like Centrafuse has, where it states Connected or Disconnected.
    Awesome Program again. I will have the Install Updated and Uploaded in just a little bit with this new version.
    Thanks,
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    Cel-D 2.4 GHZ 533mhz FSB
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    RF Mini Kb w/Trk Ball
    7" Lilliput Touch Screen Monitor
    USB 2.0 Hub
    Rikaline GPS-6010
    PN11 802.11b Wireless
    XP Pro
    750W Inverter
  6. #36
    guino's Avatar
    Nov 2004
    Toronto, Canada
    CF is made in .NET which allows the software run multiple threads and not freeze it when doing something like check if the internet is connected. RR is made in VB6 and if I don't do it propperly, everytime I'd be checking for the internet, it will likely make RR unresponsive for a second (needless to say this would suck)..
  7. #37
    Nov 2004
    I see what you mean, you are correct on that. Thanks for the Input on it.
    Bryan
    2000 Yukon Denali
    Shuttle SN65G2
    1GB PC800 Mem
    Radeon9200 PRO
    Seagate 120GB
    ATI Remote
    USB 2.0 Hub
    Rikaline GPS-6010
    XP Pro
    750W Inverter
  8. #38
    Nov 2004
    St Louis
    Note: the indicator "DIRECTION" works only with MM (currently) -- I'll also parse FD messages in the future so it works with it.
    The most important thing is that the CURRENT SKIN has the MM_*.jpg images available for drawing. Otherwise it won't work.
    The flash logo works, but you're basically overwriting the area of the logo (and that was "granted" on previous version) -- but won't work from now on... you should either reduce the size of the flash logo OR make transparent OFF/DOWN and ON images to where it only draws the buttons outside the area used by the flash logo. To do that, you just have to make BMP files instead of JPG (lossy), and make the transparent area (where not to draw) PINK (Full Red, Full Blue, No Green).
    Got mine working... so cool .
    Hey Guino, GREAT JOB. I got back from my 45 day European backpacking, babysitting, walkabout late last month. Can't believe the major mods going on. Took me 2 weeks just to catch up with reading the forums.
    Keep up the outsanding support!
  9. #39
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Hi Guino, GREAT JOB as ALLWAYS!!!. Is there a chance we can see the weather background to look like BAV2 skin. And also change the "TV Button" to weather on the main page. Thanks!
  10. #40
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by goosey2099
    I'll be doing some skinning soon:
    -Change the XM Icon on the BMV2/BAV2 skins to a Sattellite (so it can be used for SIRIUS or XM).
    -Slightly change the SIRIUS Screen to remove the song position slider (not supported)
    -Make Weather screens for the BAV2 skin
    If anybody has any request for minor changes on the Brushed skins, better speak up now..
    I'll also be adding some dynamic imaging commands to allow loading of images on commands .. Load an Image on the Empty layers is already in place for skin definition, but I'll add support to load them on Any layer (Empty/On/Off/Down/All) and allow to load them by commands (i.e. pressing a button)... this will allow skinners to make a Play button that changes when pressed and such.
  1. RR 06-06-05 .. Winamp Library Support ...
    By guino in forum Road Runner
    Last Post: 06-19-2005, 12:36 AM
  2. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 10:37 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 01:48 AM
