Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 77
Thread: RR 08-02-05... SIRIUS Support ...
  1. #41
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I'm dumb about his weather thing. Will someone quickly explain how I install it? I put it in the RR folder, now what?
  2. #42
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    check readme.txt for rr.ini parameters that need to be added, then edit your skin to add a button with the command "WEATHER"
    Roy
    2005 Range Rover 4.4
  3. #43
    São Paulo, Brazil
    Guino, instead of running the weather by using a city from rrconfig ini, could you perhaps alter it to something like "WEATHER;||=Sao Paulo, Brazil;WORLD" which could allow for somthing like "WEATHER;CUSTOMFDCITY||=,Brazil;WORLD" or whatever syntax (due to mixing "Sao Paulo" text with CUSTOMFDCITY as a variable) is required... this would allow us to customize the weather pulling info from say ou favorite GPS program, it would allow us to have a button to switch from like "Home Weather" "Weather at the Beach"... could allow us to have a little clickable map with the area around us and so forth...
    Roy
  4. #44
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    OK two things.
    1. Can we have a weather units for the UK so speed is in MPH and temperature is in C (I assume those are the only differences between the weather units)
    2. As there are sunrise and sundown times in there, can these be used (if available) to switch day and night screens. (maybe you could have seperate variables for these which are updated whenever you get new infor from the weather module)
  5. #45
    São Paulo, Brazil
    I second switching skins based on sunrise/sunset times... although doesnt the builtin gammacontrol app have support for calculating that?
    Roy
  6. #46
    Sep 2003
    LA, CA
    i tried to keep RR running normal without specific line in RR.ini
    i would like to get that function to calculate sunrise/sunset
    just to begin with...
    try this and let me know...
    RR+.exe
    changes from original rr.exe 8/2/05...
    - save ini files in INI_PATH (INI_PATH need to be set in RR.ini)
    RR.ini
    ini_path=d:\my documents
    - restore volume stored in 'resume.ini' from hibernation
    (INI_PATH need to be set in writable directory also
    HibernateReload and HibernateAware must be set TRUE)
    - change skin automatically by time set in RR.ini
    RR.ini
    autoskin=true
    daystart=0600
    nightstart=1800
    (once you change skin in skin browser, auto_skin will be disable
    then once you change skin back to right skin depending on time, it will be enabled again)
    - added '..' in list to go back to directory where you came from
    when you go in to a item listed on 'BROWSE.RRL'
    (i use BROWSE.RRL to access into CDROM then i noticed i can not go back to music folder)
    - working on dynamic volume
    (need to figure out how to get SPEED from FreeDrive
    FreeDrive is configured to send speed value to roadrunner but not sure how to optain in RR
    this is not FDSPEED showing in RR skin...)
  7. #47
    FLAC mauri's Avatar
    Jan 2004
    Hi Guino,
    In this new release 08-05 the first launch of RR results very more slow in comparison to the preceding , and random I have errors from XP.
    I think about returning to the preceding version on my system...
    Mauri
  8. #48
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Everytime I add something to RR (Features etc) it is suppoesed to get slower starting up. I can't possibly add stuff without using more space+memory...
    I can't comment on the errors unless you provide me with at least some information on the issues.
    Ride Runner RR's Myspace
  9. #49
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Honestly I have tried few the new release.
    Twice have had error of XP (unfortunately have not read! ) and once, launch MM embedded RR, simple reset my system)
    Thanks Guino of the whole job that makes, RR remains the best sw for the Carputer!!
    Mauri
  10. #50
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Just wondering if I'm doing this right, or if infact its not possible. I am trying to create a startmenu for my skin. I have created some bmp images, and sent the bits I want transparent in pink, now when I load this as a menu it doesnt show transparent.. I'm I trying to do something thats not coded in ?
  1. RR 06-06-05 .. Winamp Library Support ...
    By guino in forum Road Runner
    Last Post: 06-19-2005, 01:36 AM
  2. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 11:37 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
