Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 77
Thread: RR 08-02-05... SIRIUS Support ...
  1. #51
  2. #52
    Oct 2003
    Quote Originally Posted by CdRsKuLL
    Just wondering if I'm doing this right, or if infact its not possible. I am trying to create a startmenu for my skin. I have created some bmp images, and sent the bits I want transparent in pink, now when I load this as a menu it doesnt show transparent.. I'm I trying to do something thats not coded in ?
    possible that the transparency color is set to something non-default?
  3. #53
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The transparent color will work to draw OVER existing images.. it doesn't mean that it will make the window transparent.. the only way to do that is really to clip the area off the window (inwhich case it doesn't need to be pink)...
    Now say you wanted to make wierd shape buttons tha go over some other stuff on the screen (like other buttons).. you could make the ON/OFF/DOWN images with the Pink transparency area to define where it should not draw (the area not belonging to the button -- not to be drawn). The benefit is really on the drawing area, basically should allow you to make buttons with weird DRAWING shapes without messing with what's around it.
    The menu you want to make can be done with the LOAD or MENU commands, as long as you clip off the areas you don't want in it (use as many clippings as necessary to make it look the way you want).
    Now, if your EMPTY image was Green and your OFF image was the above, RR would only draw the button areas where the color is not Pink, and would leave the rest Green. The EMPTY image is always drawn directly, but it could be a nice feature to allow it to define the clipping area of the window.
    Ride Runner RR's Myspace
  4. #54
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    cheers for that :-) yep I used the clipping option last night and got it working fine. Just need to find time to do some more on it now.
    cheers
    CdR
  5. #55
    Oct 2003
    Does ANYONE have the drivers for Mitchjs's sirius interface? I'm going f'in crazy...it's the only thing I'm missing...
    Dan
  6. #56
    Aug 2005
    Hi
    Is there an FAQ on Sirius? How would one go about installing it into RR excatly?
  7. #57
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by kebab
    Hi
    You need an interface board (limited availability), then just download the latest RR+skin from my site, edit menu.skin to change the button code to "SIRIUS", set the COM port on RRConfig and you're done.
  8. #58
    Aug 2005
    Im not even too sure what Sirius is I was just being curious, am I right in thinking its Internet radio which you have to subscribe to?
  9. #59
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You CAN NOT BE sirius.
    sorry coudn't resist.
  10. #60
    Aug 2005
    Get your coat......
  1. RR 06-06-05 .. Winamp Library Support ...
    By guino in forum Road Runner
    Last Post: 06-19-2005, 01:36 AM
  2. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 11:37 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 01:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
