Page 1 of 8 12345678 LastLast
Results 1 to 10 of 77
Thread: RR 08-02-05... SIRIUS Support ...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 08-02-05... SIRIUS Support ...
    In this version:
    -Added Screen Limiting Option (To limit memory usage)
    -Added Full SIRIUS Support
    -Added Weather Support (Thanks to MSCAR)
    -Improved Memory Handling
    -Fixed Issue with "ADD1" on searchfiles results
    -Fixed Issue with "SETLABEL" on switching labels
    -Fixed Issues with "DIRECTION" indicator
    -Fixed Issue with "SEARCHLIST" on XM
    Notes:
    -I'll be updating the skins to include SIRIUS support. If you wish to try it before then, download this: SiriusFiles.zip. You'll need to change/make a button to execute "SIRIUS". RR should work with ANY sirius interface as long as it provides a SERIAL/COM port for commnication with the tuner. Thanks to Chuck for the Station Art images. You should also read a few notes on Sirius support HERE .
    -Screen limiting is optional and is done by adding "screenlimit=N" to RR.INI where N is the number of screens allowed in memory (minimun of 3).
    -For now, Weather Support only works when the internet is connected. I might add Weather Cache support later. You'll need those files: Weather.zip. You should thank MSCar this code. The Weather folder should be inside RR's folder.
    -As you may have seen when I was testing a BETA version, the memory optimizations took out quite a bunch of my time during the past few weeks.. I tried about 6 different approches before defining the current one.
    For as much as I don't like to, I'll spend some time improving a few things in the Brushed skins on the next few days..
    As always, thank you for your support,
    Guino.
    PS: Special thanks to MitchJS who was kind enough to donate one of his interface boards (soon for sale) for development purposes.
    Ride Runner RR's Myspace
    Sep 2003
    LA, CA
    guino
    i found bug in builtin video player...
    i found missing fregment...
    hope it helps you saving time to find it...
    [modXM]
    Public Function getThisTime(ByVal timein As Long) As String
    'Used to format the position and duration
    On Error Resume Next
    Dim conH As Integer
    Dim conM As Integer
    Dim conS As Integer
    Dim remTime As Long
    Dim strRetTime As String
    remTime = timein / 1000
    conH = Int(remTime / 3600)
    remTime = remTime Mod 3600
    conM = Int(remTime / 60)
    remTime = remTime Mod 60
    conS = remTime
    If conH > 0 Then strRetTime = Format(conH, "00") & ":"
    strRetTime = strRetTime & Format(conM, "00") & ":"
    strRetTime = strRetTime & Format(conS, "00")
    getThisTime = strRetTime
    Exit Function
    End Function
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    You forgot to update GammaControl. Use v1.2
    Jul 2004
    Berkeley, CA
    Ok... using your SDK example. I type in RRSCREEN and I press send and I get nothing.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    funny things happening with flash ? Just updated to this version, but now it seems that the flash bit is being overwrote by image_on when hovering over, then sometimes it stays on, then other times it disappears
    CdR
    Oct 2003
    Guino - this is awesome! I can NOT believe how fast you shot out a SIRIUS update! I know you used MitchJS's interface, but you speak about a com port - isn't MitchJS's USB? Or is it creating a virtual com port? Thanks again for all your work, with any luck I'll be able to get in touch with Mitch and get my own interface...
    Dan
    Dec 2003
    Germany
    Great think on the weather addon. Will do some fiddeling with ita nd can't wait for the weather cache function
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Hey Guino, pardon my extreme ignorance, but where do I change the area that it gets the weather from?
    Roy
    2005 Range Rover 4.4
    Dec 2003
    Germany
    I second that
    Jun 2003
    Memphis - TN
    LOL, I was about to post the same thing
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
  1. RR 06-06-05 .. Winamp Library Support ...
    By guino in forum Road Runner
    Last Post: 06-19-2005, 12:36 AM
  2. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 10:37 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  4. RR 3-30-05 ... Mappoint ...
    Last Post: 04-06-2005, 12:47 AM
  5. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 01:48 AM
