Results 1 to 6 of 6
Thread: mappoint P.O.I database
    May 2005
    i don't know if there is something like this or not but i have read somewhere about extracting the point of intrest from mappoint... if this could be done do you think anyone could make it so it could be sorted like a directory and then routing could be set up... something like that or even different just it seems like a good source of info that is not being used.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I don't know if it's possible to poll Mappoint's POI other than using the nearby feature (already in RR). In any case, I'd rather have it listed by the distance to the POI than alphabetically.
    Ride Runner RR's Myspace
    May 2005
    i was thinking more like a yellow pages i guess im sure there is a thred on this alredy but can't find it... but if you could extract the poi info and sort it so you could look up resturants and ect... and get the address and other info even have a spot to enter phone numbers and save that info...
    May 2005
    i found this site
    http://www.mp2kmag.com/a53--poi.poi...t.mappoint.html
    but code means nothing to me
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Holy Crap:
    "The time needed for the application to execute will vary based on the system resources of the machine on which it is being executed. When executed on my Dell Inspiron 7500, it took a little over 30 hours to perform the entire extraction,"
    This is not a solution that can provide a fast list of the POI info from mappoint. The Database would have to be created (the 30 hours above), then the lookups would be done on the database. This database has to be nicely organized and will require at least two indexes. This means you'd have to have Database libraries installed and I have said before that I will not do that -- I work with databases, and it ****es me off .. but it doesn't prevent anybody to extract the POI info and make a "consulting" application/plugin to use in the CarPC.. have said that, I can't understand the benefit of having a separate POI database... I (personally) rather stick with the nearby feature of mappoint.
    Mar 2004
    The reason for extraction is so that you can create your own faster database and use the data in other applications.
  1. put all info from mp3 cds in a database...
    By Raas in forum Off Topic
    Last Post: 09-23-2006, 11:34 AM
  2. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 01:47 AM
  3. GPS and MapPoint 2004 questions.
    By wampa in forum MediaCar
    Last Post: 07-15-2004, 06:40 PM
  4. Replies: 13
    Last Post: 07-15-2004, 01:07 AM
  5. Need Help with MapPoint and MediaCar
    By screa_34 in forum MediaCar
    Last Post: 04-21-2004, 12:38 PM
