Results 1 to 4 of 4
Thread: PowerDVD control panel still won't hide
    Feb 2005
    I just download the latest version, but the powerdvd control panel still won't go away, I try to drag it out of the way, but it jump back to where it was. I been trying to get this to work for days now. I just found out that if I open power dvd first, and then click on Dvd in RR, then it work. But if i was to just click on dvd, it load up powerdvd, and then the control panel appear right under the skin control, and won't move nor disappear, so now how do I make RR load powerdvd first? help me Guino.
    this is what I am talking about
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You likely have a bad choice of Window name to embed.... I recommend using the PowerDVD support built into RR (as external DVD).. to try it, set PowerDVD as external DVD application in RRConfig, and set the "DVD" button to load the PowerDVD_Player.skin (Included in the Brushed skins). Once you've got it to work in the Brushed skins, it shouldn't be too hard to make a Zots style control skin for it... You should make sure the Window name you choose will embed the VIDEO window only (so that the controls don't embed instead) -- You should look up the window information of both the Video and the Controls window with winspector spy then make a unique window name for the video screen.
    Ride Runner RR's Myspace
    Feb 2005
    got it to work on my desktop, going to try it out in the car later, thanks.
    I totally got lost on the winspector spy, good thing it work after I changed the menu.skin
    btw, in the newer version of RR, is the command BASS or TREB included yet?
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I just finished adding commands to set the Balance and Winamp volume controls.. I still need to add Bass/Trebble..
  1. Could I hide control panel
    By Thinboy in forum Media Engine
    Last Post: 06-12-2004, 11:27 AM
  2. Replies: 3
    Last Post: 05-26-2004, 04:08 AM
  3. FS: USED 7" VGA TFT LCD panel w/ controller & inverter - $120!!!
    By NoPistonPC in forum Classified Archive
    Last Post: 05-19-2004, 08:49 PM
  4. WTB lilliput control panel &...
    By Tha Hombre in forum Classified Archive
    Last Post: 05-09-2004, 06:31 PM
  5. Replies: 22
    Last Post: 08-13-2001, 01:42 PM
