Page 1 of 7 1234567 LastLast
Results 1 to 10 of 69
Thread: RR 08-08-05 ... USB+Hibernation ...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 08-08-05 ... USB+Hibernation ...
    This version...
    -Added Commands to Control Winamp Volumes and Mixer Balance/Bass/Treble
    -Added No Zoom Option for BuiltIn Video Player
    -Added Loadable Images Support for Skins
    -Added Support for "status" indicator images (Play/Pause/Stop)
    -Added "Online" (Connectivity) indicator support
    -Added Support to Display DAY/NIGHT skin status (mainly for SDK purposes)
    -Added Reload Weather command
    -Improved MM Direction support to allow direction image on multiple screens
    -Improved Flash Objects Speed and integration
    -Improved Serial Port over USB support (to wait for USB devices after hibernation)
    -Fixed issue with Built in Video Time Display
    -Fixed issue with "NEXT" and "PREV" not working with SIRIUS without a playlist
    Notes: This version's main change is in regards to handling USB devices after hibernation (Serial Ports, SIRIUS and XMPCR). USB and Hibernation can be a nightmare for some devices (while others work just fine), this version has support to wait for the setup USB devices to be available for connection after hibernation and it is so robbust that you can resume with the USB device unplugged, and RR will detect the re-insertion of the device and start it up (no matter how long it takes).
    -NoZoom is for those with 4:3 screens that wish to use the built-in player with the aspect ratio of the video files (zoom options will be disabled). Add nozoom=true to RR.INI to enable this.
    -The "ONLINE" status does NOT guarantee internet connectivity, but instead it provides status of WAN/LAN/Dial-up connection to a network (that perhaps may allow internet access).
    -To improve Flash Performance, I had to remove the Flash Clipping support which means that you can't cut areas off flash objects out. In the other hand, as long as the flash object is transparent, you should be able to click through it and furthermore any button/slider/indicator drawings should work through the flash objects on the screen (as long as they're transparent).
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Jul 2005
    Newport News, VA
    Another day, another update. You are the Man.
    Athlon XP 1900+, FIC AT31 Radeon IGP320, 256MB PC2100, Toshiba/IBM 7.2K 180GB HD,
    Sony XA-300 USB Audio -> Sony CDA-M600 HU, Integrated TV-Out -> Lilliput 7" Widescreen TV (CRAP),
    Vector 700 Watt Inverter, USB Keypad Control, Windows XP SP2, RoadRunner
    May 2005
    Vienna, VA
    Awesome!
    Aug 1999
    Birmingham, Alabama (War Eagle!)
    This is definitely the one big thing I missed about RoadRunner and Guino. I think I may try RoadRunner again. I need to see how well it embeds iGuidance and other apps.
    Keep it up Guino.
    NYC
    Thank you!
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    You ROCK dude!
    FLAC mauri's Avatar
    Jan 2004
    First test and one problem:
    All the indicator (mute, overspeed, bottom up & down, (the same for Repeat,Shuffle,to default I have settings to off in RR Config. but is it visible) etc.. they are visible and I turned on.
    Example:
    If I launch RR and Audio player:
    The indicator of "mute " is active and visible, the audio work ok, if click on the button of "mute" it works on/off ok, but the indicator not, is always power on ..the same for all the indicator in all section of my skin (Dena old style)
    In the old release all ok.....
    My idea seems that RR displayed for any screen NOT the xxxxx_OFF.jpg, but xxxxx_ON to default
    Mauri
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Have you tried a different skin ?? It works fine here..
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    RR will not run
    Run-time error '5':
    invalid procedure call or argument
    with BMV2 and no ExexTBL.ini entries
    i think it is something with mute indicator in BMV2 - all gray then shuts down
    and indicators in my main skin EQ- all gray then shuts down
    2001 S10 ZR2
    Chucks Skin - to old
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by guino
    Tested for another two skin (BMV2-IRunner) the same,problem with all indicator posted above
    Launch RR, and to default set the mute audio...
    New RR problem for me!
    Mauri
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 02:55 AM
  2. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  3. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
  4. USB and hibernation solutions
    By jol in forum General Hardware Discussion
    Last Post: 08-17-2003, 01:19 PM
  5. USB Devices, and Hibernation / Suspend to RAM
    By t0ffluss in forum General Hardware Discussion
    Last Post: 01-06-2003, 09:40 AM
