Page 4 of 4 FirstFirst 1234
Results 31 to 35 of 35
Thread: How to set Winamp visualization?
  1. #31
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I have been trying anything and everything to be able to exit out of vis using the builtin feature, but up till now, it would not work...
    I have it now working!!!!!
    I am currently using the whitecap vis... What I found out was that in order for RR to detect that I started vis I had to somehow have my vis goto FS - back to reg res and then back to FS and low and behold it F***ing works...
    I don't know how many ppl are using my setup (M10k & the onboard video) and couldn't get out of FS by touching the right side somewhere...
    What I did was, write an "Autoit" script so that when the "whatever" vis you are using it would wait till the window existed then send it the correct key combo to make it go FS twice....Works like a charm now...
    I would be willing to help anyone else with this, pm me & i'll see what i can do...This just made my day!!!!!
    Even after a very very long work day!
    Guino, Maybe something to look into?? (Thanks for trying to help me out with this, way back when... )
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #32
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR only shuts off the VIS plugin by clicking the right edge of the screen WHEN IT CHANGES THE SCREEN RESOLUTION... If the plugin doesn't change the resolution then you'd have to find an alternate way to shut if off or leave it embbeded in an area so that you can press the vis button again..
    I don't understand what exactly is the problem you were having with this whitecap plugin, but if you wanted it so bad, you should have asked me to try it and I'd look at it..
    Ride Runner RR's Myspace
  3. #33
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by guino
    That I knew from reading your posts... even with my vis changing the res it still would not work...but upon going in/out/in seems to get it to detect it and make the FS touch section work...
    And wasn't just that plugin it was any of the ones that i tried...
    The way that I noticed this whole ordeal was that i was writing a script to just get my vis to to into FS without doing the double tap, cause it doesn't have an option to start in FS, and one of the times it worked but i had an error in the script so it made the screen go back to reg res and thats when i saw the little FS button in the Btm left corner and the box on the right side.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  4. #34
    Aug 2005
    my vs is working perfect. but there is one thing. I can't close is. my resolution of my screen is 800*480 the resolution of the vs is also 800*480 i tried to tap on the right side but it didn't work. the ony way too stop the vs is by pressing the Esc key. I am using the jet vs. from www.winamp.com
  5. #35
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    What you have to do is set your vis to a different res, doesn't matter what res, just so that your monitor has to change to a diff res and then RR can detect that you have started vis in FS in order to be able to make it where you can get out of it....by touching the right side...within 3/4" inch from the edge.
    I think that you can change the res in just about all vis plugin's but not sure....
    I'll will have a quick look at the jet vis plugin when i get home latter....might find another vis I like too...in the process...
    Edit: I had a look at that plugin and I see what your talkin about...I think that Guino is gona have to help you...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. EPIA video + Winamp standby problem
    By crisr in forum General Hardware Discussion
    Last Post: 08-25-2004, 06:16 PM
  2. WinAmp alternate, jetAudio 6
    By Rith in forum Software & Software Development
    Last Post: 07-26-2004, 03:21 PM
  3. Winamp Visualizations
    By LoSx in forum ME Archive
    Last Post: 03-23-2003, 03:41 PM
  4. Need help with winamp
    By dikke in forum Software & Software Development
    Last Post: 12-04-2002, 02:01 AM
  5. WinAmp 3
    By Rob in forum Software & Software Development
    Last Post: 01-26-2002, 08:00 AM
