The single click option exists for playlists (Music/XM/SIRIUS).. I can easily add it to the File Browsers but I believe that having to click to highlight then click again to go in is pretty much the same as the "double-click" currently implemented .. You can actually configure how long apart and how precise the two clicks have to be in order to act as a "double-click" (using your touch screen config tool) -- so basically, if you want the click, then click again option I'd consider setting it up on the touchscreen tool. Otherwise I can add a single click option to click and go direct into the folder clicked -- the main reason I haven't implemented it is that it fairly easy to click on the wrong folder and then require even more clicks to correct the mistake.
LinkBack URL
About LinkBacks
