Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: PNG support?
  1. #11
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by liquid_smoke
    im testing it on my shutdown screen, it comes up as a window rather than a fullscreen menu and I painted the edges of the box so it would have round corners. When it test it I can see the pink that i painted.
    Transparency is for the defined area of the screen.. if you want to "cut" your window so it is round, you should use the clipping definitions (use as many as needed) ... I do intend to add support to defining the "cut" area using the empty image (at some point)...
    Ride Runner RR's Myspace
  2. #12
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by guino
    now im confused. I thought painting any part of the image pink would make it transparent? (like in winamp skins)
    i also dont see how using the clipping function to make round corners, its a box?
  3. #13
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use many clipping definitions to make it look round... this may get difficult if you have a large round shape.. I will most likely add the PINK "clipping" support at some point (when I have time to look into it)...
  4. #14
    Aug 2003
    Chicago
    dude your confuseing the hell out of me, lol.
    Im sorry.
    I dont understand what you mean by "use many clipping definitions to make it look round" what is a definition? do you just mean to use multiple clip region object types? Or is there some setting that says to make the corners round for this clip region. If you mean the first (multiple clips) thats just crazy, no way thats going to work with out getting a huge head ache.
    Then you say " i will likely add the PINK clipping support" which makes me think that painting something pink right now does something totaly different than what i was expecting when i painted an area pink earlier.
    Currently my idea of tranparency is for something to be either completely invisible and or have different levels of visibility.
    The clipping region IMO is a type of transparency where the area is completly invisible, where there are only two options its either completely visibile or its not.
    This is what i thought i was originaly going to get by painting areas of my image PINK in photoshop. This is simple transparency, on/off
    Alpha transparency is using another channel in the image specificly for transparency RGBA and the transparency is controled by the alphachannel with 255 levels (greyscale)
    Now i know RR currently dosent support alpha transparency (this is why i suggested png files)
    Painting areas PINK is a good solution to get on/off transparency for image formats that only support 3 channels (jpeg files)
    but this dosent seem to do that in RR, and from your last post, dosent seem like it was ment to do that.
    So now i ask what does painting anything pink do?
    you said to do this in the other thread too
    buttons ontop of indicators??
    but i dont see how this is the same thing as what we are talking about in this thread.
    again im sorry if im not getting something thats super obvious, but it seems like we are talking about 2 maybe 3 completely different things.
  5. #15
    guino's Avatar
    Nov 2004
    Toronto, Canada
    As I said.. it may be difficult to make a round area out of multiple clipping definitions ("Cxx,xxx..." lines in the .skin file).. so if you have a large round shape, I would not even suggest you try that.. but when you have small round shapes (like 10 pixels radius) you could acomplish this with about 15 clipping definitions.. it is a pain, YES I KNOW. That was not the original intent of this function.
    Yes -- It is different from what you were thinking.. the PINK areas are currently for the DRAWING of buttons, indicators and such within the screens in RR.. it does not affect in any way the SHAPE of the screens/windows used for drawing -- Currently.
    As I said, I will possibly implement support so PINK areas in the EMPTY screen could define the SHAPE of the window.
    Alpha transparency is currently supported for the ENTIRE SCREEN only. Look at skin commands.txt... but this is somewhat useless when you're not in control of what's below it (Windows desktop etc..) -- even if I added PNG support, I do not believe I'd be able to load and draw the alpha channels from within the file.. but adding PINK area support like winamp does (to define the shape of the window) is possible.
    The PINK area is only to prevent DRAWING on the PINK areas, for instance whey you have something inside of (or around) a button or indicator image that you do not want to draw over when the ON/OFF/DOWN images are drawn.. This basically allows for buttons that share some area of the screen with other buttons/indicators/etc but do not draw over those areas to prevent undesired effects (redrawing over another button, indicator or logo)..
  6. #16
    Aug 2003
    Chicago
    ok, i think we are on the same page now
    thanks for your patience
  1. RR 08-02-05... SIRIUS Support ...
    By guino in forum Road Runner
    Last Post: 03-09-2006, 02:44 PM
  2. RR 06-06-05 .. Winamp Library Support ...
    Last Post: 06-19-2005, 01:36 AM
  3. RR 05-12-05... Extra FM support ...
    Last Post: 05-27-2005, 11:37 PM
  4. RR 03-12-05 .. Keyboard Support ...
    Last Post: 03-15-2005, 02:48 AM
  5. Update: 2-12-05.. Flash Support!...
    Last Post: 02-13-2005, 01:21 PM
