Results 1 to 6 of 6
Thread: Quick question regarding sendkeys
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've searched for awhile and cant find the answer i'm looking for.. i'm tryin to set up a SENDKEY command and i want it to send CTRL+Q. How do i set the command up so that it holds down the CTRL until Q is sent? I thought i read in another post all i had to do was ^q but thats not working. Here is my code
    Code:
    "SENDKEY;^q||Close"
    The close part works find it just isnt sending the ctrl+q part
    Woodbridge, VA
    Blog Entries
    55
    ok so i've discovered that i can use F12 instead of ctrl+q. Its still not sending the key. I've tried multiple ways. Here is my current code
    "Close||SENDKEY;{F12}"
    May 2005
    Vienna, VA
    "SENDKEY;^q" is the correct syntax. You might have to activate the application first. Try "ACTIVATE;Window Name||SENDKEY;^q||Close"
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    have you tried to use EXIT instead of Close ?
    why do you need to send the ^Q ? the application should close by means of just the close command... if not, the question is why ?
    Ride Runner RR's Myspace
    Woodbridge, VA
    Blog Entries
    55
    Well using the ctrl+Q command with igkeys controls the igzoom tool leelo created. But i got frustrated with it and whipped up a script in autoit to specifically close that program. I believe the reason the close command doesnt work on the igzoom tool is because its windowless and road runner has no way of closing it from windows processes (the only way you can close it at this point). I'm not really sure of an answer to that but my script is working great for what i need it to do. Thanks
    guino's Avatar
    Nov 2004
    Toronto, Canada
    if you use XP, you can use the RUN command to run an EXE file to kill the process byt its name.. thus, making ^Q unecessary..
  1. Quick Question About Grounds
    By jzgt in forum Car Audio
    Last Post: 01-29-2005, 06:59 PM
  2. Quick question for any other members (LCD)
    By septicdeath in forum LCD/Display
    Last Post: 01-11-2005, 06:59 AM
  3. Subwoofer boxes / cases - quick question
    By Pabs in forum Car Audio
    Last Post: 12-02-2004, 03:24 PM
  4. Quick question on kiosk
    By Gavc in forum General Hardware Discussion
    Last Post: 11-10-2004, 10:16 PM
  5. quick question about dc voltage
    By cdm in forum Power Supplies
    Last Post: 03-05-2004, 04:19 AM
