Results 1 to 4 of 4
Thread: Internationalizing RR?
    Constant Bitrate Pseudo Nim's Avatar
    Apr 2005
    in the snow
    Hey all,
    I'm trying to get my RR to display file listings and ID3 tags using Japanese characters, but having no luck. Here's what I've done:
    - my system locale for non-Unicode apps is set to Japanese;
    - I've tried setting Road Runner's code page (RRConfig setting) to Japanese OR System
    - Also tried turning on and off the "No internationalization" checkbox (I don't know what it does)
    - Changed font in the skin to MS Gothic (the one that is used to display Japanese characters normally)
    Nothing worked so far, but Explorer itself is able to display file names with Japanese characters properly, so I'm sure it's working at least to some degree.
    What should I do? Any help appreciated.
    Thanks,
    -pN
    Doko ni datte, hito wa tsunagatte iru...
    My BMW 335xi install
    My Subaru Impreza install (now retired...)
    Realtime audio freestyle hiphop battles online - www.letsbeef.com!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Basically you got it right:
    -Skin fonts must be chosen to support the language (for every label and playlist)
    -Set the Locale in RRconfig to The Language OR if you select 'system' then your DEFAULT standards and formats (incontrol panel) MUST be the same language to display.
    -Make sure the 'No Internationalization' option is UNCHECKED
    If you do the above and it doesn't work, I'd suggest trying a different font...
    Ride Runner RR's Myspace
    Apr 2005
    in the snow
    Weird. I'm certain that I chose the font that supports Japanese, and everything else was right.... but it still didn't work. okay, I'll keep poking at it. Thanks!
    Aug 2005
    Ohio
    I would like mine in Thai but it seems that it would really require editing the skin images for the buttons. Do skinners offer their skins in a PSD format after they are completed or only while creating?
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  2. Phoco and RR (again)
    By Enforcer in forum Road Runner
    Last Post: 08-03-2005, 09:32 AM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 01:21 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
