Results 1 to 3 of 3
Thread: Couple of small problems and 1 request
    FLAC J187's Avatar
    Nov 2004
    Boston
    Smile Couple of small problems and 1 request
    1. The skin editor, when you try to editor some controls, IE the S01 for the AudioPlayer.Skin of ALpine, the dialog box opens too big to fit on 800x600. The only way to edit some of the things is to literally change screen resolution. (I know this isn't important, but if its easy to fix, just mentioning it.)
    2. With the edior, Is there any way to make it so that the colors you save in the custom color pallette stay for each different control? It's really akward to have to write down the RGB values and enter them for EVERY control you want to change.
    3. Is there already a plan to fix the bug where +1 doesn't work after a search is executed?
    THANKS.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Sorry, this is a current limitation of the code in the skin editor..
    2-I do not know if this is possible.. I believe it is..
    3-As far as I can tell there's no bug in the +1 function when used with search results (tested both on winamp library and file searches)..
    PS: The skin editor was made by "lbooker" I merely fixed one or two minor issues with it.. so I don't know much of what's in there.
    Ride Runner RR's Myspace
    FLAC J187's Avatar
    Nov 2004
    Boston
    Yeah, I realized you didn't make the editor, I just didn't know if it was something quick and easy to fix if you make changes to the editor in the future.
    As far as the search problem goes, I thought I remember you had said before it was a known bug. Perhaps it is just something with my particular RR -I'll look into it.
    Please help.
