Results 1 to 9 of 9
Thread: Hide taskbar while navigating
    Variable Bitrate Erwin's Avatar
    Mar 2005
    Hello,
    Normally I use the option to hide the taskbar automatically. When I use RR the taskbar stay's down, even when I move the mouse cursor down the screen. When I open MM and I move the cursor down the taskbar suddenly pops up. How can I prevent this? I only want to see the taskbar when I'm completely out of RR and/or MM.
    Thanks for the help
    Hardware: Via Epia M10000, 512MB DDR RAM, 3,5" 40 Gig HD, slimline DVD-ROM & CD-R/RW, M1-ATX (PSU).
    Software: Roadrunner, Mapmonkey/Freedrive
    My Car PC project
    FD & MM voices
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    Here is how I turn on and off taskbar from RR
    B33,162,397,150,63,"SHOWWINDOW;!Shell_TrayWnd;FALS E||SWITCHBUTTON;1>>SHOWWINDOW;!Shell_TrayWnd;True| |SWITCHBUTTON;1",""
    and my exit button
    "SHOWWINDOW;!Shell_TrayWnd;True||QUIT"
    2001 S10 ZR2
    Chucks Skin - to old
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you use the Hide Task bar option, this should not be happening.. unless MM is messing with it... I'd try changing your taskbar settings (disable autohide and such)..
    Ride Runner RR's Myspace
    Mar 2005
    Quote Originally Posted by Chuck
    and my exit button
    In wich file do I need to change this setting?
    My Car PC project
    FD & MM voices
    Mar 2005
    Quote Originally Posted by guino
    Yes, I do use the 'hide taskbar automatic' option. But it still happens. I tried to swich the 'hide taskbar automatic' off, but then the taskbar doesn't go away at all.
    My Car PC project
    FD & MM voices
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Sounds like you've got some other application messing with your taskbar..
    Mar 2005
    I have no other apps running. I only have RR and MM running. When I deselect the option 'always show taskbar on foreground' (I have a Dutch Windows version, so I don't know the exact name) the taskbar stays away. But this is very annoying because the taskbar stays away at all other applications too.
    Do you have any idea what app causes this problem?
    My Car PC project
    FD & MM voices
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Well, that's the problem right there.. you want the taskbar to stay on top, but you don't want it to show up while MM/RR is running ?? that's a paradox my friend... basically, when there's any kind of window positioning (i.e. running applications) the task bar will probably show up.. but it is in fact weird that the hide taskbar option is not taking care of that (it is possible that the taskbar itself is making it re-appear when a new application is launched -- causing the taskbar to update).
    Mar 2005
    Welcome to paradox
    I guess I have to live with the option 'always show taskbar on foreground' selected.
    I thougt that there was something wrong in the configuration of MM or RR.
    My Car PC project
    FD & MM voices
  1. can't hide curser
    By terrormav in forum Media Engine
    Last Post: 06-22-2005, 11:42 PM
  2. Hide map monkey with girder
    By bigmac999 in forum FrodoPlayer
    Last Post: 05-09-2005, 02:18 PM
  3. taskbar popups
    By forevertheuni in forum WinNT Based
    Last Post: 02-13-2005, 06:17 AM
  4. Hide Button Utility
    By chuckster in forum Centrafuse
    Last Post: 01-24-2005, 10:17 AM
  5. Anyway to hide cursor?
    By CHUPACABRA in forum Input Devices
    Last Post: 10-07-2004, 09:38 AM
