Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Equalizer probs
    May 2005
    Germany
    Equalizer probs
    Hi,
    Im testing RR with BMV2. The EQ-Settings in RR schows me on the left side buttons like pop, rock ... When I touch, nothing happens. In winamp the EQ is on. Could you help me?
    Ti-ejtsch
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    you have to set the presets before you can use them. Search for "equalizer preset" and you should find your answer
    May 2005
    Germany
    Hi,
    thanks a lot, but i think my english is terrible. Where to set the presets? I searched but I cantfind anything for RR.
    Ti-ejtsch
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the SAME buttons SAVE and LOAD the presets... set the EQ settings, press and HOLD (until the button redraws) and it will save the CURRENT settings, do the same for the other buttons.. once they're saved, just click them quickly and and it will load the presets as you saved them.
    Ride Runner RR's Myspace
    May 2005
    Germany
    Hi,
    great, it works! Thanks a lot, and sorry for my bad english and missunderstanding!
    Ti-ejtsch
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    I know this is an old thred but has any one develped these settings ? I know its easy to input what the EQs do but who knows what they should be ie...
    Pop =
    Jazz =
    Classic =
    Club = etc etc
    Terran
    Woodbridge, VA
    Blog Entries
    53
    you mean the "defaults" for each setting? That could vary greatly between two different setups. Best bet is to just listen to each style of music n try to match it to your interest
    Jan 2003
    My point is there are no settings for those buttons and I would like to match the audio form in the same way a car stereo would for them not just what sounds good...
    ( if you see what I mean )
    Terran
    was Boston -> now Canada!
    Messed around with presets tonight and I have to say I need some good schooling because I am having a boat load of issues. Maybe because I'm missing something.
    How do I get JUST the eq settings to change and not the volume levels? I have been going into Winamp and loading each of the presets I want followed by loading RR and saving the settings. I then start over til I have all my presets done. The presets are working but my volume is going back to what it was when I saved the settings.
    If I am at 50% volume and I hit ROCK preset it will jump my volume back to 7% becaus it was at 7% when I saved. I think it might have something with auto in Winamp but don't I need to keep this?
    Can I just use the saved EQF files. I don't care to load separate EQ settings for each of my songs I only care to change when the GENRE changes.
    Please help.
    Thanks,
    Chuck
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Read Skin Commands.txt in what it regards to the PRESET command.. there is a way to save only Mixer, only Winamp EQ or both (default).
    There's also a way to save individual "autoload" presets for winamp EQs, and a command to toggle autoloading EQs ON/OFF... read skin commands.txt -- it's all in there.
  1. equalizer
    By psych0sys in forum Software & Software Development
    Last Post: 03-25-2008, 07:25 PM
  2. Equalizer Solution
    By cadence117 in forum FrodoPlayer
    Last Post: 02-13-2006, 11:40 AM
  3. WIP of Equalizer module
    By netsuo in forum NeoCar Media Center
    Last Post: 05-08-2005, 04:19 PM
  4. is there an optical equalizer?
    By ketchup318 in forum Car Audio
    Last Post: 04-14-2005, 03:27 PM
  5. Aux. input adapter vs equalizer
    By Dima in forum General Hardware Discussion
    Last Post: 09-13-2000, 10:46 AM
