Hi,
When I start RR and it says it is starting Phone Control my CPU goes 100% and it takes ~ 40 seconds for RR to start. Is this normal when using Phone Control?
Rgds and thanks
Ant
Printable View
Hi,
Rgds and thanks
Ant
Depends on your setup and if PhoCo can find your phone. AFAIK RR waits until PhoCo is fully loaded before it continues loading ==> look into your PhoCo settings
Hi,
Sorry I should have mentioned in my original post that if I start Phone Control standalone then it takes ~ 8 seconds to start and be fully functional. It only consumes the CPU and takes ~ 40 seconds during the RR start up process.
Ant
I think you should do some more testing.. it is UNFAIR to compare the FIRST loading time of Phoco (probably done by RR) with the NEXT loading times of phoco (either inside or outside RR)... I can guarantee you that phoco will load a whole lot faster on the 2nd, 3rd etc times.. the only reason why it takes so long to start at first is because all the .NET crap has to load up ..
Hi Guino,Quote:
Originally Posted by guino
I tested this with a cold boot between each tests so as to make it as fair as possible, the results are:-
Cold Boot -> Start Phone Control -> ~14 seconds
Cold Boot -> Start Road Runner -> RR says Starting PC for ~40 seconds
I watch the processes and rr.exe is consuming > 90% CPU and PhoneCTL.NET.exe uses only a few % for 2-3 seconds and nothing for the remainder of the period.
I assume using the trial version of phone control wouldnt affect this?
Many thanks
Ant
Quote:
Originally Posted by db2boy
Using the trial version affects it big time, because the splash screen requires user input.
If you search the phoco threads in the RR form you will find that the trail version is not recommended.
Thank you for the reply, I had aready written the response when I remembered it was a trial version. Apologies, I do normally search.Quote:
Originally Posted by Enforcer
Ant
I've noticed this too but its not the fault of Phoco or RR. My dongle just doesnt wanna immediately connect. And yes RR waits for phoco to be fully loaded before it launches itself
the new version will be more flexible on connecting to Phoco...
is it possible to have it act as if it were a normal embeded window, so say if i go to the phone screen, it loads PhoCo then and not at startup and also a close button so i can shut it down if i like without also shutting down RR.Quote:
