Results 1 to 10 of 11
Thread: Starting Phone Control takes a long time
    Jul 2005
    Hi,
    When I start RR and it says it is starting Phone Control my CPU goes 100% and it takes ~ 40 seconds for RR to start. Is this normal when using Phone Control?
    Rgds and thanks
    Ant
    Dec 2003
    Germany
    Depends on your setup and if PhoCo can find your phone. AFAIK RR waits until PhoCo is fully loaded before it continues loading ==> look into your PhoCo settings
    Lilliput 7" TS TFT, ASRock K7VM2, Duron 1,3 GHz, 512 MB DDR RAM, 30 GB Seagate HDD @ 5.400 rpm, WLAN w/ 500mW booster, Toshiba Slimline DVD-ROM Drive, D-Link USB Radio
    Download the German Voicepack 1.0 for FreeDrive now!
    Jul 2005
    Hi,
    Sorry I should have mentioned in my original post that if I start Phone Control standalone then it takes ~ 8 seconds to start and be fully functional. It only consumes the CPU and takes ~ 40 seconds during the RR start up process.
    Ant
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I think you should do some more testing.. it is UNFAIR to compare the FIRST loading time of Phoco (probably done by RR) with the NEXT loading times of phoco (either inside or outside RR)... I can guarantee you that phoco will load a whole lot faster on the 2nd, 3rd etc times.. the only reason why it takes so long to start at first is because all the .NET crap has to load up ..
    Ride Runner RR's Myspace
    Jul 2005
    Quote Originally Posted by guino
    Hi Guino,
    I tested this with a cold boot between each tests so as to make it as fair as possible, the results are:-
    Cold Boot -> Start Phone Control -> ~14 seconds
    Cold Boot -> Start Road Runner -> RR says Starting PC for ~40 seconds
    I watch the processes and rr.exe is consuming > 90% CPU and PhoneCTL.NET.exe uses only a few % for 2-3 seconds and nothing for the remainder of the period.
    I assume using the trial version of phone control wouldnt affect this?
    Many thanks
    Ant
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by db2boy
    Many thanks
    Ant
    Using the trial version affects it big time, because the splash screen requires user input.
    If you search the phoco threads in the RR form you will find that the trail version is not recommended.
    Jul 2005
    Quote Originally Posted by Enforcer
    Thank you for the reply, I had aready written the response when I remembered it was a trial version. Apologies, I do normally search.
    Ant
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I've noticed this too but its not the fault of Phoco or RR. My dongle just doesnt wanna immediately connect. And yes RR waits for phoco to be fully loaded before it launches itself
    guino's Avatar
    Nov 2004
    Toronto, Canada
    the new version will be more flexible on connecting to Phoco...
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    is it possible to have it act as if it were a normal embeded window, so say if i go to the phone screen, it loads PhoCo then and not at startup and also a close button so i can shut it down if i like without also shutting down RR.
  1. Bluetooth phone control
    By 65coupei6 in forum Newbie
    Last Post: 08-12-2005, 05:47 PM
  2. long time no see
    By carabuser in forum Off Topic
    Last Post: 07-10-2004, 09:55 PM
  3. first time post, long time reader
    By kirk fogg in forum Newbie
    Last Post: 02-19-2004, 03:24 PM
  4. Hi all long time no see.....
    By Blop in forum LCD/Display
    Last Post: 10-31-2003, 05:15 AM
  5. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
