Results 1 to 10 of 11
Thread: 2 commands at once....
    Sep 2005
    Georgia
    I prefer to load entire albums at once, i rarely create a playlist on the fly. But i get messed up sometimes when i click the Add-All button from the file chooser. I'd like to make it so that when i click the Add-All button, first it clears the playlist, then adds all those mp3s. any ideas?
    Thanks.
    Jaz
    Jaz is offline
    Apr 2005
    i think you just put a | between the commands.
    so look at your skins file, and see the command for clear playlist,
    then go to the add-all button,
    and add the command for clear playlist before it with a | between them.
    but you may want to wait for a pro to confirm this
    Raw Wave
    Jun 2004
    On the beach
    Yup, just insert a | between commands on the skin to do two commands at once.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    Quote Originally Posted by TheUni
    Thanks.
    If you use 'SELECT' then it clears the playlist and adds the current Dir, If you use the 'SELECT+" then it just adds the current Dir to the playlist.. so you shouldnt need two commands. 'SELECT' should just do what you want fine
    CdR
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by Jaz
    Just to clear up, you need the double bar - || - between statements.
    But regardless, Skull is right about "Select" doing what you want to do.
    Its not the cards you're dealt, its how you play the hand!
    Quote Originally Posted by ryuandwings View Post
    Where can I get a roll of tin foil?
    I been looking for that all over the net, but I can't find it.
    Please help.
    Raw Wave
    Jun 2004
    On the beach
    I was 50% of the way there! :-)
    FLAC J187's Avatar
    Nov 2004
    Boston
    Quote Originally Posted by Gobby
    An optomist!
    You could have said, you were 50% off
    Please help.
    Sep 2005
    Georgia
    got it guys, thanks loads. I wanted it to clear the list, add the dir, and start playing all in the same step. Here's the command for anyone who was curious:
    B22,010,351,198,048,"CLEARLIST||SELECT+||PLAY","Se lect+"
    FLAC J187's Avatar
    Nov 2004
    Boston
    Glad you got it working.
    I Believe "CLEARLIST||SELECT" WOULD HAVE DONE THE SAME THING.
    Please help.
    Feb 2004
    Manchester
    I think just SELECT would of done the same job :-)
  1. ExecTBL Commands for Video_Player.Skin
    By Prem in forum RR Bug Tracker
    Last Post: 08-11-2005, 01:56 PM
  2. Best Commands to use for OSK via remote?
    By contaygious in forum Road Runner
    Last Post: 06-28-2005, 09:42 PM
  3. at+.... commands in phonecontrol for cdma
    By dirtylarry in forum PhoneControl
    Last Post: 05-14-2005, 04:27 AM
  4. Replies: 3
    Last Post: 03-08-2005, 02:31 AM
  5. Voice commands
    By droog in forum Software & Software Development
    Last Post: 10-17-1999, 03:21 PM
