Results 1 to 6 of 6
Thread: Iguidance Double instances in RR
    Jan 2004
    Does anyone have a problem of when using road runner and while an instance of Iguidance is loaded when you hit the GPS button, you decide to go back to the main screen and hten hit the GPS button again and another instance of Iguidance loads again? Is there a solution to have only one application loaded?
    I've also recently installed skinbedder(love it) but now also have multiple instances of skinbedder as well. Any inputs?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    what skin are you using and what is the code that the button that goes to gps is using?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR checks if an application is already running before trying to (re)start it... if this is happening is because you have the WRONG WINDOW NAME to embed -- and so, you probably don't have the application embbeded propperly either. There's a FAQ on embbeding applications that you should look at.
    Ride Runner RR's Myspace
    Low Bitrate widower's Avatar
    Jun 2005
    I had the same problem with ms Streets. And I had the CORRECT WINDOW name programmed. Once I updated to a newer version of rr, things worked fine.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by widower
    what is the correct window name for ms streets? I was under the impression that the window name changes.
    Jan 2004
    Quote Originally Posted by guino
    Thanks for the tip, I was reading up on the embedding facts and now i'll know what to do, thanks!
  1. iGuidance Font Size Fix summary thread
    By Viscouse in forum GPS
    Last Post: 03-28-2006, 06:21 PM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  3. Replies: 9
    Last Post: 08-02-2005, 03:12 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 12:20 PM
