Happy birthday, thanks for all your hard work!
Happy birthday matey!!! Dont get too pished![]()
Happy birthday hope you have a great day and thanks for a great frontend and all of your hard work supporting it![]()
happy bday!!!!!! yeah someone contacted me about cnet, but i don't have time to write the dayum article!!!!!!!!
random videplay hopefully coming soon..........![]()
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
Thanks for the birthday wishes guys...
The MMI skin changes are exactly as I got from Hematec.. you may need to add a "SMS" button to it (if I recall correctly) -- I'll work on the Brushed skins SMS support when I have some time..
I've fixed the ".." bug mentioned in this thread and a tiny bug when loading a playlist from library and iPod (on a rare case the playlist wasn't being updated).
You can re-download the binary package and unzip the RR.EXE from it over your current one for those fixes.
EDIT: Also fixed a wrong delay for startting XMD tuners.. (also on the binary package now).
Ride Runner RR's Myspace
Those are the current reviews.. there's a "submit yours" link on the left:Originally Posted by Meelobee
http://reviews.cnet.com/4520-11382_7...ml?tag=dir.suy
Found a problem in skin commands.txt
In the phonebook list command
PXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX,XX X,XXX,XXX,XXX,XXX,TRUE,XX,"Arial Narrow:B"[,AA]
the brackets at the end of the command shouldnt be there, it removes the format of your font from being bold, if you remove the brackets format is ok
The brackets are a symbol to indicate that that last parameter is OPTIONAL.. by no means they should be included.
Hope you had a great Birthday. You deserve it for all the great work you've done on RR.
I can't find any info on the FM preset buttons. Also can I use the "REQUEST" command to get MM to update the Direction indicator and the next maneuver labels ("MM;Nextroad", MM;Distance", "MM;Direction")?
Do I have to use a button or can I automate it to run every 5 minutes? Also what syntax would I need to use?
Happy Birthday Guino!
Thanks for all the great work.
on the
"allows you to use tags of non-Mp3 files within RR (for instance AAC, MP4 etc) . As long as the Winamp Library or iTunes is aware of the tag format, RR should be able to load and display them."
When using .MP3 files I get artist and track but I have most of my music encoded as .OGG and in RR they only display as track name. Winamp reads track, artist and track number.
