Page 4 of 4 FirstFirst 1234
Results 31 to 37 of 37
Thread: RR 09-09-05 ... Yup, it's my Birthday!
  1. #31
    Variable Bitrate slimmegane's Avatar
    Feb 2005
    Italy/Lecce
    Happy Birthday from all Italy Guino!!!
    Bye
    ITALIANI: DISPONIBILI MODULI OEM GPS:
    http://www.mp3car.com/vbulletin/show...214#post639214
  2. #32
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    A week after mine, I stayed home and was boring, go party for me too!
  3. #33
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Happy Birthday!!!!!!
  4. #34
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by GizmoQ
    Hope you had a great Birthday. You deserve it for all the great work you've done on RR.
    I can't find any info on the FM preset buttons. Also can I use the "REQUEST" command to get MM to update the Direction indicator and the next maneuver labels ("MM;Nextroad", MM;Distance", "MM;Direction")?
    Do I have to use a button or can I automate it to run every 5 minutes? Also what syntax would I need to use?
    I believe the code is "FMPRESET" ... I'm pretty sure its in skin commands.txt.. I am unsure if Request will work with complex parameters (such as MM;xxxx) I'd have to look at it, but I know for a fact that this will not have any influence in MM as to update or refresh any information...
    Ride Runner RR's Myspace
  5. #35
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by HyperSprite
    When using .MP3 files I get artist and track but I have most of my music encoded as .OGG and in RR they only display as track name. Winamp reads track, artist and track number.
    As I said in the main post.. RR is only ID3 enabled. If you want to use other file's tags, you should turn ON the winamp library, have it catalog yous songs and then use the Artist/Genre/Album options to load songs from the Library directly onto the playlist. If you simply load the files, RR will assume they're NOT in the library and won't try to load their tags from the library.
  6. #36
    Mar 2005
    Germany
    @guino
    1st: belated HAPPY BIRTHDAY to you
    2nd: i think you forgot to but the skinfiles for sms in the zip-file. or i'm to blind to see
  7. #37
    Feb 2004
    Happy B-Day from me too.
    Thank you for all your hard work.
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  2. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
