The update tool only works when RR was installed through the installshield.
The link for the installshield is not updated and needs to be fixed (I have no control over it)... Check the Install FAQ thread for the working link.
@ Guino,
The RR download link seems broken on your site. Also the updater program I have keep bombing out whn previously it worked fine. Error is Runtime 429: ActiveX can't create object...![]()
My Nissan 200SX @ Silverstone
NOW SADLY WRITTEN OFF!
My Car's spec list + pics
Stealth CarPC fab'ing...
Ride Runner RR's Myspace
I'll try to put together an installshield package unless Bryan appears within the next day
It was installed that way, and the updater has worked fine for over a monthOriginally Posted by guino
This is strange. I've been auto updating RR for ages, yet now it won't update, and I can't view either of the webpages where it's hosted... Yet I can from my works PC![]()
Sorry, I have nothing to do with the update tool, I have no code, no info and no way of debugging the issue... the message suggests that you uninstalled an application and it removed a control the update tool needed, but I have no way of figuring it out ... you should try to talk to 'drait' about it..
I had the same problem at home, I couldn't download from Guino's site, but at work I can fine.Originally Posted by Tuned Vitesse
I've just moved and am awaiting a reconnection of broadband.
could be your ISP's DNS settings
I suspect that the ActiveX error is because my PC (for whatever reason) is unable to connect to the sites where RR is hosted. I've tried the MPUG site too and thats the same...
Fair enough if the update tool doesn't work but I can't even download the Binaries anymore. All Guino's other links and downloads work fine except for RR binaries![]()
The binary downloads are working fine here - sounds like something local to you mate.
would someone mind emailling the latest Binaries to me --> shawjohn76 AT tiscali DOT co DOT uk
Many thanks.
John
