You can easily pull up this info from RR and perform/display whatever with it.. You could even do it in flash if wanted...
feature request: native gps support
but not for navigation!
One thing ive wanted for a long time is more usefull features for my GPS.
Navigation is very usefull, but only really usefull when you are lost or trying not to get lost, which isnt a whole lot, driveing around where you live.
The top things i want to use my GPS for on a daily basis
1. volume based on GPS speed (i can define a lot more on how it should work)
I know there is something to do this for people with destinator, but what about everyone else?
2. speedo with heading and optional user set speed warnings
these are the main two thing i REALLY REALLY want to do with my gps and put it to more frequent use. Putting this into RR would be cool, but i think it should be added as a plugin the way CDRIP is so that other people with different frontends can also use this or run standalone.
Ride Runner RR's Myspace
I use labels from RR to get speed, heading and elevation. I configure RR as if it was using Mapoint and just use my own skin for Navigation.
I use DeLorme Serial Emulator with one com for RR and one for iGuidance.
ExecTBL.ini
"GPS","LOAD;EXTERNAL_GPS_ig.skin;Navigation;E:\Program Files\iNav\iGuidance\iGuidance.exe;iGuidance||ACTIVATE;RoadRunner"
would be nice to convert heading to imanges. – all ready have Map pointers
WOW, i never knew you could do thatOriginally Posted by Chuck
so from what your saying, RR actually reads the data from the gps device?
If it wernt 2 in the morning i would head out to the car and test this out now.
So what about volume, does that work also?
Originally Posted by liquid_smoke
Yes RR will read from gps if you set it for mappoint and GPS com Port in config.
volume on work
OK, i got this working
sweet,
a few comments
for gps speed can we change the display of 'Mi/h" to mph it just looks odd that way and for heading can there be an option for North, West, South,East, or N,W,S,E,NW,SW etc, the degrees is also a little weird, i have to translate the degrees in my head.
Is that a yes or no?Originally Posted by Chuck
noOriginally Posted by liquid_smoke
I'll see what I can do about Heading Indicators.. the GPS volume has been on the to-do list, but it's a pain in the @ss to test, so I haven't really had time to work on it.
You can split the GPS data to iGuidance and RR by using an external application (Xport, etc).. some cost a lot of money.. check the support software forums for those apps.
