This is very possible, in fact, FD's SDK is based on the same SDK functions in RR, so you just need to place the labels you want in the skin, tell FD to send the data you want to RR (FD's SDK.INI) and whenever FD and RR are running this info will be updated. You can also place the "DIRECTION" indicator on your skin(s) and if FD sends the next maneuver, RR will update the picture.. You do need the MM_* files on your skin before the directions work. You should read about FD's SDK in FreeDrive's forums..
LinkBack URL
About LinkBacks
