Check in RRConfig that its not trying to use the same com port as MM for sat radio or temperature sensor
Hi, I have a little trouble using Map Monkey in RoadRinner after the last RR Update: If I start Map Monkey from RR the software said: com port in use.
If I start only Map Mokey all works good!
Can someone help me?
...sorry for my english
Chrysler 300C Touring 2006 CRD
My ex car - Alfa 147 project
Italian Rock Band! http://www.pikasso.it
ok thank's a lot I'll check it this evening!Originally Posted by froop
If you're only using MM, make sure not to set the GPS com port in RRConfig itself, MM only needs the gps port setup on its own settings. You should only set the port in RRConfig if you intend to use Mappoint.
Ride Runner RR's Myspace
