Results 1 to 4 of 4
Thread: YASQ: Skin Paths not correct
    Variable Bitrate Viscouse's Avatar
    Jul 2005
    Motor City
    Unhappy YASQ: Skin Paths not correct
    Yet Another Skin Question.
    Sorry I didn't know if this was supposed to go here or the Skins forum. If I did it wrong please tell me.
    I'm trying to make a skin_browser.skin but it's not cooperating.
    If I use the BAV2 skin, hit the "Skins" button, I get a proper menu of the 3 skin directories I have. No problem.
    If I load up my POS skin, hit my "ExitMenu" button to go to my ExitMenu, then hit the "Skins" button I load my skin_browser.skin but I see my MP3 list instead.
    Almost everything is the same between the 2 files.
    How do I tell my skin where to look for skins?
    EDIT...here's the code...
    Code:
    MEDIACAR Skin
    MEDIACAR skinbrowser Skin
    /, J, x, y, w, h
    J,336,115,309,334
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, played color R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,116,115,209,334,255,255,255,000,000,000,255,245,000,000,000,000,255,255,255,TRUE,15,"ARIAL NARROW:B"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L03,9,20,73,25,6,226,32,10,"LCD Display Grid:B","TIME","CENTER"
    L04,9,44,73,25,6,226,32,10,"LCD Display Grid","DATE","CENTER"
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B22,112,10,60,70,"SELECT",""
    B16,629,9,60,70,"EXIT","Exit"
    B08,369,521,60,70,"EXIT","Exit"
    B05,14,436,60,70,,""
    B04,14,355,60,70,"VIDEO",""
    B03,14,265,60,70,"AUDIO",""
    B02,14,179,60,70,"GPS",""
    B01,14,95,60,70,"XM",""
    B50,655,124,25,100,"PGUP",""
    B51,655,339,25,100,"PGDOWN",""
    END
    You know you want to...Worklog
    Enjoying v1.0 since it's operational. Aaaawww yeah.
    Specs: Opus120; Epia M10k; 700IDT; GlobalSat BR-355; iGuidance 2.1 & IGMod; XM; Custom case.
    Witty one-liners currently quoted by (0001) mp3car.com forum member sigs.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The number of elements on the S definition changes (items separated by comma).. you're probably not using the correct format to display the skin list. You should most likely copy the definition from the BrushedMetal Skin and then change the values as necessary. It is also important that the file is called skin_browser.skin, but I guess you got that much figured out.
    Ride Runner RR's Myspace
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    It looks like you may have put the wrong type of "S" definition in there. Try the following: (you may need to adjust the colors)
    /, S, x, y, w, h, forecolor R;RGB, G, B, backcolor R;RGB, G, B, selected color R;RGB, G, B, select color R;RGB, G, B, trs, font size;FONT, font name
    S01,116,115,209,334,255,245,000,000,000,000,000,00 0,000,255,255,255,TRUE,15,"ARIAL NARROW:B"
    Also, I see some typo's in the screen settings (skin_men u.jpg) and in some of the color codes.
    Jul 2005
    Motor City
    Thanks (again). That did the trick. Sometimes it's hard to know which def to use. I thought I copied it correct, but I guess not.
    DiNASTY, those typo bothers me too. It is correct in the file, but shows up funny when put in the BB software.
  1. Replies: 36
    Last Post: 12-13-2005, 07:38 AM
  2. Replies: 0
    Last Post: 06-05-2005, 12:40 PM
  3. Frodoplayer and Skin Question
    By Jemmi in forum FrodoPlayer
    Last Post: 02-14-2005, 07:46 PM
  4. night skin day skin problem.
    By fallnangel in forum FrodoPlayer
    Last Post: 02-02-2005, 08:08 AM
  5. skin problems with frodo
    By outdidya in forum FrodoPlayer
    Last Post: 09-07-2004, 10:33 AM
