Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: RR 09-28-05... EQ stuff...
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Arrow RR 09-28-05... EQ stuff...
    In this version:
    -Added support for autoload EQ presets for individual songs
    -Added winamp EQ ON/OFF commands and indicators
    -Added command to directly set mixer line volumes
    -Added folder list click event for custom commands
    -Improved transition between loader screen and main screen
    -Improved CDRip with option to rip to "Artist - Album" folder structure
    -Improved "list follows song" option to highlight new songs on audio browser
    -Improved Extra Browsing Screens support to pull the last used path by default
    -Fixed issue with reloading skins with ExecTBL.INI
    -Fixed ThumbList and Thumbnail views to work without 'show icons' option
    -Fixed issue with temperature sensor from 9/23
    Notes:
    -Use "SAVEEQ" and "SAVEDEFAULTEQ" to save winamp auto-load EQ presets. Make sure the Auto-load preset option is ON first (winamp). There are new indicators and commands to toggle the autoload of presets and winamp's equalizer. The DEFAULT EQ is what is loaded for songs without an autoload preset saved (if Autoload is ON).
    -Clicking on an item at a directory list will set off an "ONDLCLICK" event (exectbl.ini).
    -When switching between browser screens the last used path/location will be automatically transferred to the new one as long as the PATH parameter of the SD definition is not present.
    Thanks for your support,
    Guino.
    Ride Runner RR's Myspace
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    WOOT!!! Directory Browsing!!!
    PS: you got my donation the other day right? just confirming since I didnt hear further from PP
    EDIT: IT WORKSSSS!!! THANKS GUINO!!!! WOOT
    One observation Guino: now, when I click a directory in the list, it immediately starts playing that directory... This is fine in most cases but when I'm looking for a specific song in a subdir it is a bit bad to have 2 or 3 songs start playing cause their in other subdirs... would it be possible to split the Directory click and the File click (in the dirlist)? I also notice that I can go into any directory simply by clicking once on it... I like this!
    Overall I love this release!
    Highlighting is wokring great, as is staying in the last used directory!
    Roy
    2005 Range Rover 4.4
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I may be able to split the clicks onto two separate events..
    São Paulo, Brazil
    Cool that would be the best of both worlds! Single click directory opening, as well as single click playing, with the ability to navigate through directories!
    Roy
    FLAC Chuck's Avatar
    Sep 2003
    Ellicott City, MD
    I don’t know what happened but it takes about 7 or 8 seconds for me to switch between skins now. And sometimes a window frame comes up around RR.
    Edit
    >>>>>>>>>>>>>>> Rebooted and it seems to work ok now <<<<<<<<<<<<<<<<<<<
    2001 S10 ZR2
    Chucks Skin - to old
    Newbie maxzor's Avatar
    Feb 2005
    Italy
    Quote Originally Posted by Chuck
    I've got the same problem!
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Wow.... I cant keep up..... 2 versions this week - new newly build v3 is out of date already.
    Nice on Guino
    Terran
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by RoyN
    now, when I click a directory in the list, it immediately starts playing that directory... I also notice that I can go into any directory simply by clicking once on it... I like this!
    i just grabed this update and i dont see this behavior. When i click on a directory it just highlights it and dosent autostart playing music, i have to double click to go into the dir too.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    This behavior is only if intentional.. you'll need to define "ONDLCLICK" on exectbl before it does anything -- I'll most likely be splitting that command onto two others (ONFILECLICK and ONDIRCLICK) as requested..
    guino's Avatar
    Nov 2004
    Toronto, Canada
    How big is our ExecTBL.ini file ??? The only thing changed was that I when loading a new skin, I need to reload ExecTBL.INI (the main one) plus the one from within the skin (if any).
  1. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  2. How to insert Eq Graphics Bar in RR Skin?
    By slimmegane in forum RR Skins
    Last Post: 09-28-2005, 12:53 AM
  3. Which EQ?
    By accentsound in forum Road Runner
    Last Post: 07-18-2005, 03:09 AM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
  5. Winamp 2.9x and 5.x EQ.
    By stevewm in forum Software & Software Development
    Last Post: 12-23-2003, 10:17 PM
