Results 1 to 9 of 9
Thread: Can RR Run an external application on startup?
    Low Bitrate GARB-E's Avatar
    Oct 2004
    If yes......... How?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    i believe it can, how, im not sure
    but... the more simple way to do it would be to use a bat file to launch RR and the other app you want to start. You can also set RR to kill the external app when it shutsdown via ExecTBL.ini
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use the start command option in RRConfig for this along with the RUN command -- details are in skin commands.txt.
    Ride Runner RR's Myspace
    FLAC arebelspy's Avatar
    Sep 2005
    San Luis Obispo, CA
    Quote Originally Posted by guino
    Quick Q about this...
    Skin Commands tells me as an example:
    "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD;NOTEPAD"
    What if my path to the App has spaces or is a long filename or something? Do I need extra quotes in the middle, or will it work fine just like that, or how do I do this?
    -arebelspy
    See my trades here! My For Sale/Trade Thread. Email joe at eipse.com
    Quote Originally Posted by xdjxklusivex
    i think every thread is now a whoreing thread
    Sep 2005
    San Luis Obispo, CA
    Looks like the first extra "notepad" in that example makes it embedded and the second makes it spoken.. i need neither, but when i try
    "RUN;C:\path to my app\app.exe" it doesn't work.. any suggestions anyone that knows more about the RUN command?
    EDIT: To give you more info, I'm basically setting rr as my shell, and want it to run a matchvolume exe at startup. it's located in a subfolder of "Program Files" (so path has a space and is a long filename).
    -arebelspy
    Sep 2005
    San Luis Obispo, CA
    Tried it, doesn't work.
    Neither of these work:
    "RUN;C:\path to app\app.exe"
    "RUN;"C:\path to app\app.exe""
    Anyone have any experience with the RUN command and can comment?
    -arebelspy
    Maximum Bitrate tolisn's Avatar
    Dec 2003
    Greece
    How about this
    It works for sure
    runq;C:\program files\freedrive\freedrive.exe|hidden
    I’m using this at the moment to load my gps program. The hidden option is for the gps program.
    The road is long but we are getting there.
    Sep 2005
    San Luis Obispo, CA
    Hmm well I figured it out just before you posted that, but thank you, I really appreciate the help!
    I removed all quotes (around RUN, around long path with spaces, etc) and it worked.
    Thanks again though.
    -arebelspy
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Pause music in external application mode
    By zummi in forum Media Engine
    Last Post: 07-13-2004, 12:33 PM
  3. Mediacar V1.8.5
    By coyote in forum MediaCar
    Last Post: 02-16-2004, 02:16 PM
  4. PowerDVD as external application
    By MontrealCL in forum ME Archive
    Last Post: 05-17-2003, 06:13 PM
  5. More than one external application?
    By KlereBak in forum ME Archive
    Last Post: 02-12-2003, 08:31 PM
