Results 1 to 3 of 3
Thread: problem with ExecTBL.ini priority
    SMKFree liquid_smoke's Avatar
    Aug 2003
    hey guino:
    when RR is loaded and it finds the ExecTBL.ini inside the skin folder, The ExecTBL.ini file that is in the ROOT still has priority over the one loaded from the skin folder.
    So for example if i have this command in the ExecTBL.ini file in the root
    "ONDIRCLICK","RUN;C:\playfile.exe|C:\Music.wav "
    and this command in the ExecTBL.ini file in the skin folder
    "ONDIRCLICK","RUN;C:\playfile.exe|C:\Sound.wav "
    when there is a conflict of the same command found twice, the root file takes priority, since whoever is making a skin cant know what what is in the root file on anyones machine, the skin file should take priority if a duplicate command is found.
    so in the example above Sound.wav should play instead of music.wav
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Noo... the main exectbl.ini should take priority over anything else in order to allow overriding functions defined on the skin's exectbl.ini -- otherwise, there's really no need for the main INI. If you consider the fact that 90% of the users don't even touch that file, this should not become an issue at all, and in the case it does for the 10% that mess with it, those users know how to open the main INI and set things straight.
    In your example, if a user already has say: "ONDIRCLICK","BROWSE" and your skin's definition took over it, then the desired function would go away. If this user (that knows about such settings) wants to, he can simply combine your command with the original one in either of the INI files.
    Ride Runner RR's Myspace
    Aug 2003
    that makes since, i guess i was a little confused then as to how the second file was loaded.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 08:29 AM
  2. A little problem with my car... Maybe...
    By BoyNextDoor in forum Power Supplies
    Last Post: 11-13-2004, 08:58 PM
  3. MedicaCar Volume Problem -- Need Help
    By BrUTaL in forum MediaCar
    Last Post: 11-09-2004, 08:27 PM
  4. Media Car not responding... Lilliput problem?
    By carpcnoobie in forum MediaCar
    Last Post: 09-01-2004, 01:38 PM
  5. cordless phone problem
    By jstrain in forum Off Topic
    Last Post: 06-24-2003, 11:09 AM
