Results 1 to 6 of 6
Thread: mute- unmute radio
    Sep 2005
    mute- unmute radio
    I have cinergy600 , input line as "mic"
    In the RR config , setup "unmute mic"
    question :
    when updown the radio , the sound is open....
    when shutdown the radio ( return of main menu) the sound is open ???
    play the music , the sound of the radio is mixing for player for the music.
    Why ?
    In the latest upgrade of RR , the player menu , not exist, exist only selected menu.
    is well ?
    what command in the skin setting for play the song ?
    The "stereo" mode , in cinergy600 not exist?
    The RR + ZOT skin , very very beatiful !!! ;-))
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    1-Using the Microphone as input will DECREASE SIGNIFICANTLY the quality of your RADIO.
    2-As long as you selected the Microphone line to mute/unmute in RRConfig it should work (As long as your sound card works right -- try updating drivers and such if you have issues)
    3-The Radio playback stays ON until you return to the Music Player or Open the VIDEO/DVD/XM/SIRIUS screen.
    4-The Cinergy card does not provide interface to know if a station is stereo or Mono, it only lets you FORCE it to one or the other (RR leaves it to auto select).
    I don't understand any of this:
    is well ?
    Ride Runner RR's Myspace
    Sep 2005
    [QUOTE=guino]1-Using the Microphone as input will DECREASE SIGNIFICANTLY the quality of your RADIO.
    ok , what using for input radio ? The only external input is mic... :-?
    The sound card is ok.
    the mic input is disactivates only when RR exit
    when music player is on , is on the radio.... Two sound in mixing ;-)
    VIDEO/DVD/ecc , is ok.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I'd suggest making a cable using the CD-IN our AUX-IN plug commonly found on the motherboards .. the Mic quality is a lot lower because it is amplified from the low gain mics used on PCs.. This should also fix the issue with the mic line not muting when exiting Radio -- some cards just don't work right with the mixer interface.
    Variable Bitrate rijk's Avatar
    Feb 2007
    netherlands
    I want to use the mixvebes U46mk2 as a soundcard. It Doesn't show all the speaker outputs in win. speaker setup, But by using the 5.1 plugin for winamp all speakers work with mp3's. It online has a mic-in (input 1, 2, 3, 4 ) i want the radio to use input 1 and 2.
    With an other soundcard i found out, in order to get 5.1 sound, the radio needs to use the Line-in plugin in rr. I used: line://title=Radio,srate=48000,bps=16,nch=2 and the line used for mute disabled.
    Now my idea was to use mic://title=Radio,srate=48000,bps=16,nch=2
    But no sound. When i mute / unmute the mic there is sound output 1 and output 2.
    What do i need to change in to get the line-plugin to work with the mic?
    Feb 2007
    netherlands
    I found out the setting in windows of the recording device determent what line will be used. The u46 doesn’t have a selectable recording device, so that won’t work.
    The other soundcard, the terratec has a line in and a mic. Looking what’s the previous posts i want to use the line.
    I have selected the line in the recording options. Closed windows and than restarted the pc, this works. Then i have don the same with hibernate, works. The last thing i tried was the standby, doesn’t work. No matter how i select, when the pc is on it has changed the input from line in to mic. The only time it doesn’t do this is when i have opened the sound-icon an selected the recording tab. When that one is open it switches back on with te line in as the recording device.
    So there is 2 things i can do,
    1 have the sound-section start up with recording devices opened
    2 find the file where windows has the default recording input device.
    I looked in regedit, but no luck.
    Ideas are welcome.
  1. How to enable mute line in on radio?
    By danl in forum Road Runner
    Last Post: 08-15-2005, 11:20 AM
  2. Radio volume doesnt mute
    By miztahsparklez in forum FrodoPlayer
    Last Post: 03-06-2005, 04:45 AM
  3. Replies: 11
    Last Post: 02-24-2005, 11:51 PM
  4. Line In Mute problem with Radio...
    By ShawJohn in forum MediaCar
    Last Post: 08-20-2004, 05:21 AM
  5. Radio mute in Mediacar
    By greddy0 in forum MediaCar
    Last Post: 04-09-2004, 04:54 PM
