Results 1 to 3 of 3
Thread: Offset for phidgets / temperature sensor
    Maximum Bitrate skippy76's Avatar
    Mar 2004
    Cambridge, MA, USA
    Hi,
    Due to a little inaccuracy in the phidget temperature sensor, I need to apply an offset to the sensor value.
    Guino: Please could you add the following code to Road runner:
    - modRoadRunner: New version of set PhidGet func
    'Set PhidGet Temperature Sensor Info
    Public Function GetPhid(CODE As String, Fmt As String) As String
    Dim S As String
    Dim N As Double
    On Error Resume Next
    'If can't find it, return N/A
    If PH Is Nothing Then GetPhid = "N/A": Exit Function
    'Get Sensor Value
    N = PH.SensorValue(Val(Mid(CODE, 5)) - 1)
    'apply offset (added by skippy76)
    N = N + PHOffset(Val(Mid(CODE, 5)))
    'Get Tip Data
    S = Fmt
    S = Mid(S, 2, Len(S) - 2)
    'See if need to apply conversion
    Select Case LCase(S)
    Case "c2f"
    'Show in C
    N = N - 200: N = N / 4
    N = (N * 9) / 5: N = N + 32
    GetPhid = Format(N, "0.0F")
    Case "f2c"
    'Show in F
    GetPhid = Format(N, "0.0C")
    Case "volt"
    'Show in V
    N = N - 500: N = N * 0.06
    GetPhid = Format(N, "0.00")
    Case "50amp"
    'Show in Amps
    N = N - 500: N = N * 0.1
    Case "15amp"
    'Show in Amps
    N = N - 500: N = N * 0.03
    Case "gp"
    'Show in Pressure
    N = (N / 4) + 10
    Case Else
    'Return Sensor Info
    GetPhid = Format(N, S)
    End Select
    End Function
    - Add this to the select in LoadSettings of rmLoader
    ' Phidget offset
    Case "phidget1"
    PHoffset(1) = DT(1)
    Case "phidget2"
    PHoffset(2) = DT(2)
    Case "phidget3"
    PHoffset(3) = DT(3)
    Case "phidget4"
    PHoffset(4) = DT(4)
    Case "phidget5"
    PHoffset(5) = DT(5)
    Case "phidget6"
    PHoffset(6) = DT(6)
    Case "phidget7"
    PHoffset(7) = DT(7)
    Case "phidget8"
    PHoffset(8) = DT(8)
    - Add this line to the decs in the modRoadRunner module
    Public PHoffset(6) As Long 'Phidget offsets
    06 Volvo XC90
    Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
    Car PC downloads: http://carpc.harteveldt.com/
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Done... also, I changed the DT(x) values on loadsettings (all of them) to = Val(DT(1)) ... you had them going up to dt(8)...
    Ride Runner RR's Myspace
    Mar 2004
    Cambridge, MA, USA
    Excellent, thanks!
    Well spotted on the DT(x)... I was a bit over zelest on the copy / paste changes I guess!
    Your the man! (wht the woman still I hope!)
    Andrew
    06 Volvo XC90
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  2. Ideal location for a temperature sensor??
    By carpcnoobie in forum General Hardware Discussion
    Last Post: 10-07-2005, 01:07 AM
  3. Phidget Temperature sensor calibration
    By skippy76 in forum Road Runner
    Last Post: 10-05-2005, 11:47 PM
  4. Real temperature solution - what do you think?
    By dmurray14 in forum Centrafuse
    Last Post: 01-24-2005, 10:38 AM
  5. MPJA - MECI ASTEC DC-DC Converter
    By Luc in forum General Hardware Discussion
    Last Post: 11-22-2004, 10:31 PM
