My RR is also very slow after i last reinstalled windows.
Still frustrated with the slow launch times, I went and uninstalled version dated 10/7/05 and put back version dated 5/12/2005.
All is back to normal now (about 3 to 4 times faster launching menu buttons).
In addition, the volume slider issue I was having is no longer.
I'm using the BMV2 and Zots skins just downloaded from the rr page. So far no issues.
If I can't get the newer versions to run right on my system, what major features will I be lacking?
MEDIACAR Skin
MEDIACAR "audioplayer" Skin
audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
Whats up with that. Im seeing ****. there is a space between "audio_pl" and "ayer_on.jpg" but when i quote it it fixes itself.
Anyone else see that or have i been up too long? If im not seeing things then TheKingPlazza: is that how the file has it too?
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
Yep I'm also seeing the space
The road is long but we are getting there.
I had the same problem too... I did a fresh install of windows yesterday, the volume problems are over now...Originally Posted by jjfta
RR is running slow as in my previous install, i also used another Win XP Pro cd.
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
I noticed this also. It started maybe 3-4 releases ago, I wish I could remember which one. Maybe I can reload old releases until I can figure out where it started. Each screen is very slow to load ONLY the first time. Once you have loaded it up one time them it is very zippy.
I find exactly the same thing. I just put it down to the hardware im using, but maybe its not the problem?
I find that the first time a screen loads it takes ages, but once its up its very fast between screens (almost instant)
Chrishick or others,
Have you been able to determine what version of RR you started to experience the long load times? I we can isolate the version, maybe it will be possible to determine the problem. (something changed that isn't agreeable to systems)
My project had been on the self since May. I only just recently started working on it again. Hence, I do not have any versions other than the current and one dated back in May of 2005.
i wish i knew. It was somewhere between the beginning or mid september when i noticed it. I thought it was because my epia wasnt able to keep up all the sudden. But if this problem is noted throughout the community then maybe its not that.
I'll try and make up some "speed" tweaking settings to where you'll be able to turn off a few standard features and then play around with those to try and find out what's causing it to be "slow"...Originally Posted by Sonicxtacy02
Ride Runner RR's Myspace
