installed macromedia flash? newest version?
Hi!
Today i did a fresh install on my desktop PC. I use it to test roadrunner and skins. Since then Road Runner runs really slow... I have to click on buttons 4-5 times before they work... Sometimes RR hangs completely. This is kinda strange, cause before the fresh install there was nothing wrong...
I used the same software as before, only now updated versions.
I use:
Roadrunner
Skin: LS3.0 ver4
Winamp 5
How is this possible? Did i miss something?
Thanx for your help!
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
installed this one,
http://www.macromedia.com/shockwave/...ShockwaveFlash
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
I also noticed this today in my car setup.
When playing some folders/mp3's kinda use abnormal performance. hit the next/forward button normaly plays next song, but after latest update it only forwards the slider. My car setup hasn't changed since february 2005. Tomorrow I'll try a fresh (RR) install to see if it solves any problems.
ive been noticing similar issues... takes a while to respond when searching through a video file on the slider, doesnt refresh as fast anymore
'05 Acura TL w/ Navi & Bluetooth, JL Audio Cleansweep, JL Audio XR650 CSI, JL Audio XR650 CXI, JL Audio 300/4 Speaker Amp, Eclipse SW6123.4 12" Sub, JL Audio 250/1 Sub Amp, Optima D35 YellowTop Battery http://www.cardomain.com/ride/2184473/1
Diddo. I've noticed it to. Movie between menu selections takes a good 5 seconds. Latest updates and zots skin.
strange... everything runs normal now... Sometimes it just happen again, slow running and system hanging (RR). Only option then is CTRL-ALT-DEL..
AsRock AM2 dual VGA
AMD Sempron 3000+
512MB DDR
3,5" 80GB harddrive
Liliput 7"
TFT 15"
M2-ATX
0% [OOOOOOOO-] 100%
My install
Anyone have any luck figuring this one out. My menu selection are all extremely slow when selected for the first time (5 to 10 seconds). I have installed the latest flash. I have even reinstalled windows (as my carpc is still on my desk being tweaked). I used a different version of windows xp pro this time. I still have the same issues, extremely high cpu demand when starting and selecting menu buttons in RR. (all buttons excepte "minimize" and "Day/night", and mute). I have checked my ini file, looks good to me.
Also, maybe some has come across this problem. When I first touch the volume control (after rr boots), sound stops. I have to move the slider all the way to zero then back up to get sound. Once this is done volume controls function normally.
Which skin are you using, do you have the latest flash + OCX ? Can you post the first 3 lines of some of your .skin files ?
Your slider problem seems very much like a driver issue... some SB cards are known to have bad drivers... I'd suggest looking for an updated driver before anything.. RR only reports a slider at a certain location when/if it is being reported (from the drivers) as in that location... and it unmutes the line prior to any adjustments (exactly to prevent issues like yours)... I can only assume the sound card is saying the audio is at X% when you actually have no sound..
Ride Runner RR's Myspace
MEDIACAR Skin
MEDIACAR "audioplayer" Skin
audio_player_off.jpg,audio_player_off.jpg,audio_pl ayer_on.jpg,audio_player_down.jpg
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B02,500,0,150,60,"VISU",
B03,300,520,100,80,"VOL-",
B04,400,520,100,80,"VOL+","Volume+"
B05,0,520,150,80,"PREV","Prev/FW"
B06,500,520,150,80,"PLAY","Play"
B07,650,520,150,80,"NEXT","Next/FF"
B08,150,520,150,80,"STOP","Stop"
B09,175,217,200,200,"LOAD;Audio_List.skin",
B10,0,0,150,60,"EXIT","Exit"
/, I, x, y, w, h, Code;INDICATORCODES
I,675,118,80,30,"REPEAT"
I,675,87,80,30,"SHUFFLE"
B12,150,0,150,60,"MIXER",
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,74,133,600,30,192,192,192,20,"Decker:B","TAGAR TIST","SCROLL-LEFT"
L02,74,83,600,40,255,255,255,28,"Decker:B","TAGTIT LE","SCROLL-LEFT"
L04,75,351,80,30,254,5,0,14,"Decker:B","KBPS","Tra ck bitrate"
L05,75,307,80,30,254,5,0,14,"Decker:B","KHZ","Trac k freq"
L06,75,394,80,30,254,5,0,16,"Decker:B","TAGYEAR",
L08,409,486,50,30,255,255,255,16,"Decker","VOLUME" ,"LEFT"
L10,75,262,80,30,254,5,0,14,"Decker:B","CURRENTTRA CKTIME","Current track time"
L11,75,215,80,30,254,5,0,14,"Decker:B","TRACKTIME" ,"Total Track Time"
L12,633,487,40,30,255,0,0,16,"Decker","=ETR","RIGH T"
L,41,487,60,30,255,0,0,16,"Decker","=CPU","RIGHT"
L,183,487,50,30,255,0,0,16,"Decker","=CASE","RIGHT "
L13,500,487,40,30,255,0,0,16,"Decker","=ETA",
L14,343,486,50,30,192,192,192,16,"Decker","=Vol"," RIGHT"
L,686,487,60,30,255,0,0,16,"Decker","CUSTOMFDETR", "LEFT"
L,552,487,60,30,255,0,0,16,"Decker","CUSTOMFDETA", "LEFT"
L,641,422,100,40,255,255,255,24,"Decker","=Km/h","LEFT"
L,531,422,100,40,255,255,255,24,"Decker","CUSTOMFD SPEED","RIGHT"
L22,413,333,330,40,255,255,255,22,"Decker","CUSTOM FDROAD","LEFT"
L,637,304,100,20,192,192,192,14,"Arial","=Satellit es","LEFT"
L23,588,304,40,20,255,255,255,14,"Arial","CUSTOMFD SATS","RIGHT"
L24,532,379,200,30,255,255,255,18,"Decker","CUSTOM FDNEXTMAN","LEFT"
L25,415,379,100,30,255,255,255,18,"Decker","CUSTOM FDNEXTMANDIST","LEFT"
L15,75,437,300,30,255,255,255,18,"Decker","TAGALBU M","SCROLL-RIGHT"
L16,113,487,52,30,255,0,0,16,"Decker","MbM1","0.0C "
L17,247,487,52,30,255,0,0,16,"Decker","MbM2","0.0C "
B,473,205,250,60,"SHUFFLE/REPEAT",
B11,400,294,350,150,"GPS",
/, J, x, y, w, h
J01,175,217,200,200
/, A, x, y, w, h, color;RGB
A01,30,170,740,310,000
END
