Results 1 to 5 of 5
Thread: audio player problem
    Aug 2004
    video player problem
    Is this a bug or am I the only one having this problem .When I go into video player and then browse for video its and play them its fine when I go back into music it still has the videos in my playlist instead of the music I had loaded before into my playlist .
    May 2005
    That's because there is no seperate playlist for the video browser. (Guino: will this be added?) Maybe you can add some command to the music button so it clears the playlist before it shows it, but that will also happen when you have selected music.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    well, if it is switching from video to audio mode, then your playlist should be automatically restored... what skin are you using ? can you produce a debug file of when you get the problem ? (add debugmode=true to RR.INI run RR, make the problem happen, then post debug.txt)..
    Ride Runner RR's Myspace
    was Boston -> now Canada!
    I can switch back and fourth without issue. My music playlist is restored as Guino states.
    Aug 2004
    Hmm weird it started working correctly now thanks don't know why it was doing it before
  1. Audio Problem...
    By Cheekz185 in forum CF Bug Reports
    Last Post: 09-03-2005, 01:29 AM
  2. designing audio system
    By 1DeepG in forum Newbie
    Last Post: 06-29-2005, 09:48 PM
  3. RR 2-27-05 Audio Browser problem
    By Curly_cat in forum RR Bug Tracker
    Last Post: 03-02-2005, 02:40 PM
  4. VIA M10000 on-board audio input problem
    By rjoek in forum Car Audio
    Last Post: 01-26-2005, 06:34 PM
  5. Connect hand held MP3 player to car audio system?
    By jasonwood in forum General Hardware Discussion
    Last Post: 10-31-2001, 12:30 AM
