Results 1 to 7 of 7
Thread: How to load a new skin after "n" sec of idle?
    Oct 2004
    I want the audio_player skin to load a embbed vizualization skin after "n" sec of idel on the audio_player skin. Then once touch the visualization skin it will switch back to the normal audio_player skin. is this possible in RR?
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Quote Originally Posted by civic5zigen
    not possible currently, but a cool idea, kind of like a screen saver but could be used other ways, i would want to load a different screen that maybe was just a fullscreen speedo.
    Great idea !
    Raw Wave
    Jun 2004
    On the beach
    Thats a really good idea ... could be used for all sorts, maybe a choice of which screen to show depending on the screen you are currently in.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    this can be done already in flash skin..
    Oct 2004
    care to explain a bit more?
    Maximum Bitrate DiNASTY's Avatar
    Mar 2005
    Concord, California
    It's possible to "time out" to the vis skin simply by setting a timer in flash that calls the skin using an fscommand. You could also configure the "n" sec in a txt file as I'm sure everyone will have a different preference.
    The problem, however, is going to be with the visualization itself. Currently, there is now way to put a button over a vis window so it would be impossible to have it switch back to the audio_player skin on "one-touch". Secondly, you would be limited to the AVS vis because most other visualizations such as Milkdrop require music, Thus if there is no music playing, RR will timeout to the vis skin and pop-up an error message. Sorry for the lengthy response..
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Flash is definitely an easy alternative here.. nothing to be displayed even.. but I have thought about adding a skin definition to allow a command to execute after so many seconds, with or without a "reset"... I Think Arathranar actually had done some work on that, and just didn't have time to post the changes..
    Ride Runner RR's Myspace
  1. Open Source Skin Editor for RR
    By lbooker in forum Road Runner
    Last Post: 04-16-2007, 01:51 AM
  2. Replies: 0
    Last Post: 01-20-2005, 05:27 PM
  3. load soft ware to usb hard disk then load to comp
    By tracker92 in forum General Hardware Discussion
    Last Post: 08-29-2004, 06:57 PM
  4. Takes MediaCar Mixer like 20 sec to load
    By antimatter in forum MediaCar
    Last Post: 05-24-2004, 03:13 PM
  5. For all you guys having skin load problems...
    By CarComp in forum ME Archive
    Last Post: 03-11-2003, 10:09 AM
