Page 10 of 22 FirstFirst 1234567891011121314151617181920 ... LastLast
Results 91 to 100 of 219
Thread: iGuidance NATIVE in Road Runner
  1. #91
  2. #92
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    is the euro ver of IG3 available yet?
    i wonder if they use mapdata for europe from someone other than navteq, other than that cant see why they wouldnt release both at the same time. Personally i think the people at inav are lazy.
    beer replenishment fund
    mp3car live search
  3. #93
  4. #94
    Aug 2003
    Chicago
    nope, they dont work
    mp3car live search
  5. #95
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by liquid_smoke
    If i navigate away from the gps screens, IG will no longer accept commands or sendkeys, is it possible for you to not hide it so you still see IG in the taskbar.
    I may have to release iG windows when not embeded and no in gps mode.
    If i use the reloadskin command, which is supposed to kill all embeded apps and reload the skin. If i go back to the gps screen IG will not reload.
    This also happens if i manually kill the process in taskman and return to the gps screen IG will not reload.
    This is because when iG running, I set a flag and check it later if go back to gps mode again without reloading the shell command. May have to change that.
    Also.. if i happen to have a window open with iGuidance in the title bar (firefox with this thread open for example) RR will grab this window (this happens with every embeded app in RR) but if i kill the window (this window) IG will not launch either.
    Seems that if RR thinks it has found its windowname to embed it will not ever look for this windowname or check if the process is running again unless you exit RR completely.
    This is because RR search for partial window name.
    In your screenshot above, how did you remove the status bar at the bottom?
    And how and where do i use SetWindowRgn ?
    In RR code (APIStuff.bas), there is a routine RemoveBorder(). You give it the handler for the app and the size you want to display. I have to possition iG windows (with menu) 20 pixels higher than the display area. When RemoveBorder routine is called, it chop the top 20 pixel. Result is the removal of menubar. This is only for iG3 because without the menu, it crash (like previous version). For other app (includes iG2.x), SetMenu(apphWnd, 0) API will remove menubar.
    Thanks for taking the time to do this mod, the flashing and constant flickers when you click on anything, was super annoying to me, esp at night.
    I wonder if any of your changes can also be used for other embeded applications, they all flicker like this.
    The flickers is the main reason I want to moddify.
    Embeded app flicker when click on skin buttons because of gain and lose focus before and after sendkeys command.
    When I set the embeded app as a child window of RR, no more flickers.
    I'll try to see if anything else I can do to other embeded apps.
    Thanks for the feedback.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  6. #96
  7. #97
    Aug 2003
    Chicago
    cool,
    didnt know the remove border thing was already in RR, prob just being used for video and or web.
    Nice job, ive been testing it since i got the email, and other than the issues i posted about everything else seems to be working nice and fine.
    Initially my status bar and file menu were still visible, but i think it was because the name of my .skin files and a lot of other IG3 stuff i have going on in my skin. But everything seems to be fine now after making some adjustments to my skin.
    i wonder if the SetWindowRgn could be exposed through ExecTBL.ini or in a button command to use for other non IG windows.
    hats off, this is just the spit pollish that IG needed in RR. No more need for skinbedder and the like.
    mp3car live search
  8. #98
    May 2005
    Vienna, VA
    Matrix, does the embedded IG have a window presence, say, in the Task Manager? Most of igmon's functionalities depend on it.
    On a side note, I've never noticed any "flicking" issue with embedded apps inside RR. I always set my A region to be the same as the C region. My skin buttons work just as expected. The only small problem is that the builtin SendKey doesn't work reliably all the time so I use AutoIt scripts for those.
    iGMon - Integration between iGuidance and Road Runner
    CFX - Skin for Road Runner
  9. #99
    Sep 2003
    Beach City, Socal
    Actually credit should go to oeri for the idea of removing menubar via SetMenu and RPM_VR4 for nudging the window up.
    RemoveBorder() routine was use to trim the border around VIS windows and MPC in RR. I just take advantage of it .
  10. #100
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by b8bboi View Post
    The embedded iG windows isn't present if you just use FindWindow/Finwindowex. Does iGMon take the handler? If so, we can set it up to work.
    Because I save the handler for IG once it became the child window of RR so sendkey works really well.
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 01:40 PM
  2. Replies: 5
    Last Post: 05-25-2005, 07:38 PM
  3. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 12:42 PM
  4. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 03:16 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 12:16 PM
