Page 13 of 22 FirstFirst ... 345678910111213141516171819202122 LastLast
Results 121 to 130 of 219
Thread: iGuidance NATIVE in Road Runner
  1. #121
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Okay, I just found some problem with this beta mod and existing skins.
    If your gps skin file has a Clip Area, it will show the destop instead of iG. Why? Well, after iG became the child window of RR in the application window (A) and at the same time RR clip that area. The result is that RR cut out (iG). Clip area help with flicker like b8bboi said above, but with this beta, there is no need for iG GPS windows. You may use it in launch skin but not iG GPS.
    Those who use Freedom skin by CDR, take note the following.
    - In external_gps.skin file remove CLIP area by putting a comment (/) in front of it.
    Code:
    /, C, x, y, w, h
    /C01,193,122,590,378
    - in Menu.txt file change the value for gpsfull to
    Code:
    &gpsfull=LOAD;external_gps_full.skin;$gpsname$;$gpspath$;$gpsname$&
    - Rename gpsfull.skin file to external_gps_full.skin and remove (Comment) the CLIP area
    Code:
    /, C, x, y, w, h
    Everything should work.
    Playerbeat, LS, I'll send you the latest update. Please host it. Thanks.
    This update will fix the following reported by Ls.
    - When ReloadSkin command is run and go back to gps, iG doesn't load.
    - Manually kill iG process via task manager, iG won't load when go back to GPS.
    Thanks guys.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  2. #122
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    lo peeps.. thought I would let you know what I changed in the included rr.exe with freedom.. its not much, it just allows me to grab the current values for winamp / preamp / balance etc.. and pass them onto flash..
    below is the code I changed.. your quite welcome to include it in your version then everyones happy.. lol
    Code:
    'Check if custom line volume
    If Left(LCase(LTag), 4) = "vol;" Or Left(LCase(LTag), 4) = "vol:" Or Left(LCase(LTag), 4) = "volf" Then
    Select Case LCase(Mid(LTag, 5))
    Case "balance"
    s = s + CStr(Balance)
    Case "treble"
    s = s + CStr(Int(MixerState(MaxSources + 1).MxrVol / 655))
    Case "bass"
    s = s + CStr(Int(MixerState(MaxSources + 2).MxrVol / 655))
    Case "winamp"
    s = s + CStr(Winamp_GetVolume)
    Case "preamp"
    s = s + CStr(WinAMP_GetPreAmpValue)
    Case Else
    If Left(LCase(LTag), 8) = "vol;freq" Or Left(LCase(LTag), 8) = "vol:freq" Or Left(LCase(LTag), 8) = "volffreq" Then
    s = s + CStr(WinAMP_GetEQValue(Val(Mid(LTag, 9)) - 1))
    Else
    s = s + CStr(Int(MixerState(IDXName(Mid(LTag, 5))).MxrVol / 655))
    End If
    End Select
    End If
    just to a find vol: in the project and it will come up :-)
    CdR
  3. #123
    Sep 2003
    Beach City, Socal
    CDR, are these the only 2 lines you change?
    Code:
    and
    Code:
    If so, I'll add it in.
  4. #124
    Feb 2004
    Manchester
    yes thats them.. its because you cant set variable names in flash with a : or a ; in them so I just added a f instead.. Its still not fully right as I cant get the current setting for the mixer lines like 'line in' 'aux' etc.. the problem being is each sound card is different and I havent sussed out how to poll the mixer line for the names.. maybe something like a mixerline1, mixerline2 etc... might work were mixerline1 = the first slider etc.. then at least I could get the current value which would make it work as it should rather than blind if u know what I mean.
    also the line &gpsfull=LOAD;external_gps_full.skin;$gpsname$;$gp spath$;$gpsname$& above.. would this work for all gps apps.. if so I will add it to the next release to save any problems
    cheers
    CdR
  5. #125
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by MatrixPC View Post
    Code:
    /, C, x, y, w, h
    Code:
    Code:
    /, C, x, y, w, h
    Thanks guys.
    Quote Originally Posted by Enforcer View Post
    Never mind
    had to modify the skin file.
    for iGuidance to run properly before I had to clip the application area, now I have removed my clip line it works fine.
    *cough!
  6. #126
    Constant Bitrate Playerbeat's Avatar
    Apr 2005
    San Jose, CA
    7" TouchScreen Carputer
    Rockford Fosgate 1501BD and Rockford 551s
    12" MTX 9500 in a SS* or a 12" Brahma in a SS*
    ZAPCO COMPONENTS in front and RFs in rear
    2 YellowTops and a 200amp Iraggi Alternator
    *Snell Shell box from nolteaudio.com
  7. #127
    Sep 2003
    Beach City, Socal
    Enforcer, With offical RR, you need clip area to avoid the flicker, but that also make the desktop show during enter and exit iG GPS.
    With this beta, you don't need clip area, because that will cut out the area where iG suppose to be. This is only true for iG GPS (external_gps.skin and external_gps_full.skin). In app (launch.skin), you do need clip area to avoid flicker. That may change if I find a solution to properly embed other apps.
  8. #128
    Aug 2006
    Using Freedom skin by CDR, and I added the updated rr.exe file (8-16), did the clip edits in the skin files and menu.txt like above. How do we get rid of the taskbar when IG is running in the skin? It's quite annoying, and I didn't see any fix for it in the previous posts.
  9. #129
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by drPheta View Post
    RR.exe that CDR include in with the skin doesn't fix anything with iG. That one only fix/enhance in regard to the mixer.
    The beta in this thread release by me and hosted by Playerbeat is the one that will fix the way iG embedded in RR. Give it a try.
    Download link is on post 126. Just extract and rename it back to exe and run (once it work the way you want, you may rename it back to RR.exe and back up the official release.)
  10. #130
    Aug 2006
    Did all that, and IG works fine. It's just the taskbar that shows when in GPS mode in CDR's Freedom skin.
    Temporary fix for now is to make the taskbar auto-hide itself. May be a permanent fix this way. However, one can also advent this little quirk by making RR their shell.
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Replies: 5
    Last Post: 05-25-2005, 06:38 PM
  3. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 11:42 AM
  4. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 02:16 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
