Page 5 of 22 FirstFirst 123456789101112131415 ... LastLast
Results 41 to 50 of 219
Thread: iGuidance NATIVE in Road Runner
  1. #41
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    Done! Until there's a better solution, for anyone else that is looking to incorporate iGuidance into RR, here's what I did:
    Installed iGuidance. Downloaded iGmod and decompressed to some folder. Left Mappoint integration as is. In RR config, select the GPS button to go to MENU. For navi path, set it to the folder and executable for iGmod. Set Window name to igm.
    What happens:
    Now, when I run RR and hit GPS, I get the menu that allows me to opt for Destinator (which I don't have), Mappoint, and External. Obviously, Mappoint launches mappoint inside of it's integrated skin as before, and external launches iGmod, which opens iGuidance in the External GPS skin.
    My opinion:
    I am very excited about this b/c I get iGuidance accessible from RR, and still have access to Mappoint, which I am comfortable with. At the moment, I am favoring iGuidance as it loads MUCH quicker than MP. MP is superior regarding POI, but I like the interface of iGuidance with iGmod much better, even though it seems a bit buggy. Also, the arrow representing the vehicle tends to "stick" to the road, so if the map is off a tiny bit, you can't tell. I'm very happy at this point. I hope the RR integration gets even better! I have a great feeling that it will. Thanks to all working on this project. -Alan
    :EDIT: I spoke too soon. For some reason, iGuidance hangs now when launched through RR as described above...it was working earlier. what gives? If I launch iGuidance on it's own, everything is cool; however, when I launch via RR (calling iGmod which calls iGuidance) it just hangs. I'm wondering if the nag screen is existing in the background. Doesn't iGmod get rid of the nag screen? ...and just when I thought I had it workin......
    :EDIT AGAIN: okay, so I think I might have figured out my problem...to get MP AND iG running on the same instance, I need a COM port splitter...time to search
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  2. #42
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try searching for Xport, is was written by someone on here.....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  3. #43
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    What is that thing that says Message[2]?
    Peace,
    Rafster
  4. #44
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by Blue ZX3
    I did, found it, and tried it, but can't seem to figure out RR settings for this. It's very frustrating. I split the COM port, and use one for MP and the other for iG. But whenever I try to set it up, the GPS Port keeps getting reset to zero in RRConfig.
    I wonder if anyone has successfully implemented iGuidance AND Mappoint/Streets&Trips at the same time. I can't seem to come up with any search results on this.
    500+ full albums
    4,000+ video games
    old carPC
  5. #45
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    I have both iG and streets 06 running together on my system without an issue. Using xport 3, i have those, streets 05, compass, RR, AND sirfdemo running at the same time... each off a different port
  6. #46
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Quote Originally Posted by ITL
    I know your problem, I run into it and I just really **** me up.
    There are 2 ways to solve this problem.
    1) GPS mode set for External (for iGuidance) under RR config so when click on GPS, iG will run as external. Well unless you guys modified this part of the code.
    Now manually edit RR.ini file and add mappointport = whateverGPS_COM_PORT_IS
    You are done.
    2) GPS mode set for Mappoint under RR config.
    Well, you have to use the RUN command to run GPS proggy (iG) for all GPS buttons on the skin.
    Because if GPS mode set for Mappoint, mappointport entry will be in RR.ini file. Other GPS mode, RR config will not write that entry to the ini file.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
  7. #47
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by MatrixPC
    You are done.
    Thank you very much. Looking forward to trying this out.
    1) I see, but how would you launch MP from RR? I assume just by setting RRConfig to use the MENU for GPS.
    2) I will try this one, first. It seems more feasible.
    Thanks again I'll report back once I check it out.
    500+ full albums
    4,000+ video games
    old carPC
  8. #48
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The mappointport setting is only saved from RRConfig when Mappoint or OTHER is selected from the list of GPS selections. but you CAN set it manually as posted.
    Ride Runner RR's Myspace
  9. #49
    ITL
    ITL is offline
    Jul 2004
    Atlanta, GA
    Quote Originally Posted by guino
    understood, but what would make it revert to zero?
    500+ full albums
    4,000+ video games
    old carPC
  10. #50
    Aug 2005
    This is going way off topic....
    A
  1. Road RUnner and Navi Voice
    By cdevelasco in forum PowerVoice
    Last Post: 07-20-2007, 12:40 PM
  2. Replies: 5
    Last Post: 05-25-2005, 06:38 PM
  3. Road Runner sceen for iguidance
    By Kalt in forum RR Skins
    Last Post: 05-16-2005, 11:42 AM
  4. How do I install Road Runner ?
    By guino in forum RR FAQ
    Last Post: 03-21-2005, 02:16 AM
  5. Road Runner Facts...
    By guino in forum Road Runner
    Last Post: 02-21-2005, 11:16 AM
