Originally Posted by
liquid_smoke
Command request:
Hey guino
Do you think you could add a few more commands for GPS, like GPS1,GPS2 etc, up to 5 just for good measure.
So when using "GPS3" for example, it would load your gps screen, just like it does when you use "GPS" command, but it would load a different screen.
So you can have External_GPS, External_GPS2, External_GPS3 etc and not have to put the path to the app in button code.
This way, whenever a gps request is made, RR looks at what is set in RRConfig for the path and window name, thus making configuration less of a mess, or absolutes as with my skin.
I tried to make my own commands , and they work when used alone, but if i use multiple commands they nolonger work, but i think the above method would be best and less chance for people make mistakes etc.
