Results 1 to 3 of 3
Thread: Problem with hybernate and touchscreen
    Jul 2005
    Birmingham,UK
    I know this problem is not a RR problem so just asking for advice. I use a Lilliput screen with Touchscreen but when I select hybernate in RR the computer hybernates correctly but immediately resumes again. If I disconnect the touchscreen USB it works OK. Is there a way to disable the touchscreen USB driver from within RR before RR issues the hybernate instruction and enable it again on resume or has anyone have a fix for this problem.
    Many thanks.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You can use the ONSUSPEND and ONRESUME events of ExecTBL.ini to execute a command to disable the touchscreen and to re-enable it.. this can be done by running DEVCON.EXE on RR's folder. You may want to use a .bat file for ease of setup.. but nonetheless, I think most users have a touchscreen and don't have this issue, so sounds like it could be something else...
    Ride Runner RR's Myspace
    Jul 2005
    Birmingham,UK
    Thanks Guino, did as you suggested and works like a charm.....Great software and support. Thanks.
