Results 1 to 10 of 12
Thread: Transparency for album art
    Aug 2005
    Just wondering if there was a way to define an area for an image and have it set to a certain transparency level.
    For example, I wanted to set a region in my audio player for album art behind some buttons. And I don't want it to be at full brightness.
    All my album art is .jpg, so I don't know if this is possible, or if RR even supports this.
    Thanks.
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    this can be done in flash, its quite easy to learn, just go and grab swishmax, its loads easier to learn than flashmx and I could give you a few pointers to get you on your way
    CdR
    Aug 2005
    Thanks. I would be interested in that.
    So will the flash file that I create be used as an overlay of my album art .jpg images? So when I select an album, the .jpg image is displayed, but with a transparency.
    Or do I have to modify every .jpg image to have a transparency.
    I already have flashmx and have used it to do some simple things for my website. If you could let me know what the basic process is, I can try and figure out the details.
    Or I can get swishmax.
    Feb 2004
    Manchester
    if you grab swishmax then I will send u a file that will show you whats going on. Guino added a albumart label, which holds the route the the current cover. In flash you can import this art work and do what you want with it. :-)
    CdR
    Aug 2005
    I downloaded swishmax, so if you send me the file I can check it out.
    Thanks.
    May 2005
    Vienna, VA
    CDRSkull, any idea on how to implement an auto-switching flash that toggles between album art and Freedrive's turn direction indicator and distance to next turn?
    FLAC ppgt94's Avatar
    May 2001
    USA
    CdR, what skin is that? That's not for RR is it? That's sick!
    Sorry, I've been out for a while.
    Feb 2004
    Manchester
    Quote Originally Posted by ppgt94
    MC1.0 released in the skin section..
    Sorry its taken me so long to reply with a swishmax example..
    Attached is a GPS Directions / Album Art swish file.. this shows the album art, unless freedrive is routing then it shows direction and distance.
    For this to work you will need in the skin...
    F,200,200,200,200,"GPS.swf"
    J,0,0,0,0
    L,0,0,0,0,,,,,,"CUSTOMFDETA",
    L,0,0,0,0,,,,,,"CUSTOMFDNEXTMAN",
    L,0,0,0,0,,,,,,"CUSTOMFDNEXTMANDIST",
    L,0,0,0,0,,,,,,"ALBUMART",
    also in the sdk.ini in the FreeDrive folder you will need to amend these lines
    FDETA=RoadRunner
    FDNEXTMAN=RoadRunner
    FDNEXTMANDIST=RoadRunner
    thats about it :-) Make sure you have the latest flash 8 player installed as well
    hope this helps
    CdR
    Attached Files Attached Files
    Newbie carputerbear's Avatar
    Sep 2005
    Norway
    Quote Originally Posted by CdRsKuLL
    J,0,0,0,0
    CdR
    Hello CdR, greate skin! I'm using this now and i love it. But please, as a no programmer, where do i put this to get it working?
    Also, it's seems that the clock on the top of the screen is missing one number
    (eg. it shows 4:01:1 when it should be 14:01:10)
    Looking forward to the next release
    Regards
    Carputerbear
    Nov 2004
    St Louis
    J,0,0,0,0
    FDETA=RoadRunner
    hope this helps
    CdR
    O.K. What am I missing here? The file in the zip is "GPS Directions.swi" but the above example talks about "GPS.swf." How do I get this to work?
  1. Album art downloader
    By hijinks21 in forum Software & Software Development
    Last Post: 07-20-2006, 09:56 AM
  2. album art in id3 causes improper read
    By hateeecs in forum CF Bug Reports
    Last Post: 09-06-2005, 12:34 PM
  3. FRODO doesn't remeber Album Art
    By heiniheini in forum FrodoPlayer
    Last Post: 05-25-2005, 02:28 AM
  4. Album Art / Movie Art
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 04:38 PM
  5. Replies: 0
    Last Post: 11-03-2004, 11:49 PM
