Here is another Streets & Trips 2006 skin based on the Brushed Metal skin.
I have been using it for about three weeks now including a long trip last week an everything seems to be working(except the OSK, I use a different OSK so I haven’t spent much time with this one. I also have a Brushed Aluminum variant of this if anyone is interested. Enjoy!!
http://home.att.net/~cougar428/GPS_ST2006skin.zip
http://home.att.net/~cougar428/ST2006_PSD.zip
Installation Instructions;
Streets & Trips 2006 should be fully installed and functional prior to installing the skin.
Using the RRConfig Utility, enter the following information in the GPS Pane;
GPS Mode = External
GPS Path = C:\Program Files\Microsoft Streets & Trips\Streets.exe (or your install directory if custom install)
GPS Window Name = - Microsoft Streets & Trips
Copy all files beginning with the name “GPS_ST2006… to your Bushed Metal skin directory.
Rename your External_GPS.skin file to External_GPS.orig
Copy the file named GPS_ST2006.skin to External_GPS.skin
Load RoadRunner, reset your skin and test the GPS functions.
All functions are documented in the “tool tip” section of the respective .skin file.
