Page 13 of 15 FirstFirst ... 3456789101112131415 LastLast
Results 121 to 130 of 148
Thread: Brushed Metal Streets and Trips 2006 skin
  1. #121
    Mar 2006
    Colorado, but Canadian!
    Well, I just lowered winamp's volume under the settings button to about 15%-20%, and then the voice on S&T is loud enough to play over music. Usually I listen to music in the 5-15 volume range, but with that it is 80-95 range.
    No auto mute yet.
    1.9in x 2.9in -- 47mm x 73mm
  2. #122
    May 2006
    Cool, I tried that and it worked. However, when I shutdown and restart my computer it goes back to max vol. Is that a default setting in RR?
    By the way the S&T skins are excellent. I tried the turn by turn yesterday and had no probs.
  3. #123
    Mar 2006
    so I've got a question that might be really simple to answer... I just split my port so I could add my speed (gpsspd) to any screen in roadrunner (coming from ms streets and trips) now my question is what if i want to get the information for next turn on any screen? what command might that be?
  4. #124
    Nov 2005
    Missouri
    Quote Originally Posted by Softec View Post
    Here is another Streets & Trips 2006 skin based on the Brushed Metal skin.
    I have been using it for about three weeks now including a long trip last week an everything seems to be working. The OSK it calls up is the one used in WindowsXP. I Also included a Brushed Aluminum variant of this. Enjoy!!
    http://home.att.net/~cougar428/GPS_ST2006_BM_skin.zip
    http://home.att.net/~cougar428/ST2006_BM_PSD.zip
    http://home.att.net/~cougar428/GPS_ST2006_BA_skin.zip
    http://home.att.net/~cougar428/ST2006_BA_PSD.zip
    Installation Instructions;
    Streets & Trips 2006 should be fully installed and functional prior to installing the skin.
    Using the RRConfig Utility, enter the following information in the GPS Pane;
    GPS Mode = External
    GPS Path = C:\Program Files\Microsoft Streets & Trips\Streets.exe (or your install directory if custom install)
    GPS Window Name = - Microsoft Streets & Trips
    Copy all files beginning with the name “GPS_ST2006… to your Bushed Metal skin directory.
    Rename your External_GPS.skin file to External_GPS.orig
    Copy the file named GPS_ST2006.skin to External_GPS.skin
    Load RoadRunner, reset your skin and test the GPS functions.
    All functions are documented in the “tool tip” section of the respective .skin file.
    OK, Go gentle, I'm just a beginner at this skinning stuff.
    I created a skin based on the GPS_ST2006 skin for Streets and Trips.
    I am having trouble with two buttons (Buttons 12 and 18 below). I copied these directly from your skin, changing only the "Switchbutton" number (even though I dont know what it means).
    I hoped it would work exactly as it does in your skin.
    But button 12 - Text/Turns does not cycle through the four views like yours, I get the 1st one, but dont get the "Drawing Guidance" screen, then back to the full map.
    Button 18 - Day/Night displays the night view but doesnt go back to day.
    So what am I missing?
    Ignore buttons 31 and 35, I'm still trying to decide if I want them.
    Also do you now the command to display the Terain view?
    MEDIACAR Skin
    MEDIACAR MainMenu Skin
    Streets2006_off.jpg,Streets2006_off.jpg,Streets200 6_on.jpg,Streets2006_down.jpg
    /, B, x, y, w, h, Command;COMMANDCODES, Tooltip
    B02,5,82,79,42,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%VZI","Zoom In"
    B04,6,130,77,46,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%VZO","Zoom Out"
    B06,7,183,75,43,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^d","Find Near"
    B08,4,231,78,45,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^a","GPS Pane"
    B10,5,281,77,43,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%TGS","Toggle GPS"
    B12,4,332,84,46,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^u||SWITCHBUTTON;12>>ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^b||SWITCHBUTTON;12","TEXT/TURNS"
    B14,5,383,83,46,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^r","Route Menu"
    B16,3,433,84,43,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;{F3}","ReRoute"
    B18,3,480,84,49,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VMN||SWITCHBUTTON;18>>ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VMR||SWITCHBUTTON;18","DAY/NIGHT"
    B20,6,549,79,39,"Exit",Exit
    B31,103,169,60,27,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZT","ZOOM Sel"
    B35,108,344,60,24,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZR","ZOOM Route"
    /, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
    L02,7,91,75,22,255,255,255,13,"Arial","=ZOOM +","CENTER"
    L04,7,141,75,22,255,255,255,13,"Arial","=ZOOM -","CENTER"
    L06,5,192,75,22,255,255,255,13,"Arial","=NEAR","CE NTER"
    L08,7,245,75,22,255,255,255,13,"Arial","=GPS","CEN TER"
    L10,0,294,80,22,255,255,255,13,"Arial","=Start GPS","CENTER"
    L12,7,341,75,22,255,255,255,13,"Arial","=TURNS","C ENTER"
    L14,8,393,75,22,255,255,255,13,"Arial","=ROUTE","C ENTER"
    L16,6,446,75,22,255,255,255,13,"Arial","=ReROUTE", "CENTER"
    L18,7,496,75,22,255,255,255,13,"Arial","=NIGHT","C ENTER"
    L20,8,557,75,22,255,255,255,13,"Arial","=EXIT","CE NTER"
    L31,98,169,75,22,255,255,255,13,"Arial","=ZOOM Sel","CENTER"
    L35,94,344,97,25,255,255,255,13,"Arial","=Zoom Route","CENTER"
    L51,58,10,113,21,255,255,255,16,"Arial Narrow:B","TIME","Time"
    L52,58,35,113,21,255,255,255,16,"Arial Narrow:B","DATE",""
    L53,190,14,548,41,255,255,0,22,"Arial Narrow:B","TRACKNAME","SCROLL-CENTER"
    /, A, x, y, w, h, color R;RGB, G, B
    A01,195,67,604,533,000
    /, C, x, y, w, h
    C01,195,67,604,533
    END
    Thanks...Paul
  5. #125
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Switch button 12 and 18 are not working because they are not #12 or 18 in line.. They are #6 and #9 no matter what you're calling them. It is alway a good idea to number them 1 to n. In this case you would always know in what order they are for use with the switch button command.
    MEDIACAR Skin
    B01,5,82,79,42,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%VZI","Zoom In"
    B02,6,130,77,46,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%VZO","Zoom Out"
    B03,7,183,75,43,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^d","Find Near"
    B04,4,231,78,45,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^a","GPS Pane"
    B05,5,281,77,43,"ACTIVATE;Microsoft Streets & Trips||SENDKEY;%TGS","Toggle GPS"
    B06,4,332,84,46,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^u||SWITCHBUTTON;06>>ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^b||SWITCHBUTTON;06","TEXT/TURNS"
    B07,5,383,83,46,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;^r","Route Menu"
    B08,3,433,84,43,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;{F3}","ReRoute"
    B09,3,480,84,49,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VMN||SWITCHBUTTON;09>>ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VMR||SWITCHBUTTON;09","DAY/NIGHT"
    B10,6,549,79,39,"Exit",Exit
    B11,103,169,60,27,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZT","ZOOM Sel"
    B12,108,344,60,24,"ACTIVATE;- Microsoft Streets & Trips||SENDKEY;%VZR","ZOOM Route"
    Paste the above and it should work.
  6. #126
    Nov 2005
    Missouri
    Quote Originally Posted by MGD View Post
    MEDIACAR Skin
    Ahhhh... It's always the simple things that get me. Thanks...Paul
  7. #127
    Nov 2005
    Missouri
    Will this work with Delorme Street Atlas
    Will the method used here work with the Delorme Street Atlas application?
    If so how do you find the appropriate string for the various commands? (Maybe I can work this out if I understand the sendkey syntax)
    Also somewhere there must be a tutorial to the sendkey commands
    such as what does the % mean (looks like that one is ALT)
    what does ^ mean (change menu?)
    and how do you find the approprite keystroke for something like "page down"?
    Can someone point me at the tutorial
    Thanks...Paul
  8. #128
    Aug 2006
    ITALY
    HI! I living in italy and use Autoroute 2006 .
    How can embedding this SW in RoadRunner ?
    Apr 2005
    San Jose, CA
    Quote Originally Posted by pshadwick View Post
    and how do you find the appropriate keystroke for something like "page down"?
    Thanks...Paul
    The ^ = CTRL and % = ALT
    One way I found a lot of the sendkeys for Streets was looking at Keyboard Shortcuts in the Streets Help. Another way is through the menus. For example if you look at "View" on the menu it has an underlined letter V. If you press ALT V the view menu will pop down, follow the underlined letters to the command you want to run. Say Veiw, Maps, Larger would be %VMG (notice the G in Larger was the letter underlined in this example).
    As for Autoroute, I believe everything is the same but the name of the Streets.exe name, Try changing the exe name in your skit to match the exe name in the program files\autoroute and it should work. Also you will need to change the window names in the skin as well.
    I hope to post a more advanced streets skin for 2007 within the next week. I have pretty much eliminated any need to use any of the standard menus. Someone will need to re-graphic it to match the brush metal skins as I have my own skin I design to.
    Chris
  10. #130
    Aug 2006
    ITALY
    I change the exe in rr config and command line in menu.skin but no working !
    The skin is open but autoroute no starting !
    Please help me.
    thanks
  1. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  2. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  3. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
  4. Microsoft Streets & Trips 2006
    By buurin in forum GPS
    Last Post: 10-12-2005, 12:08 AM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
