Page 4 of 15 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 148
Thread: Brushed Metal Streets and Trips 2006 skin
  1. #31
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Hello Im testing the skin in the 2nd post (very nice work) with S&T 2005. Embedding works sort of, it embeds but the buttons on the side also get covered up. Is there any workaboud to this? Or should i just go get 2006. Also when ever I hit a button it seems to want to launch a new instance of S&T. One more thing is I have to boot directly into RR if i dont want the taskbar while running S&T. I really like streets and trips so if someone has any ideas I Thank you for the help. Again it was a late night of configuration, maybe if I start fresh today i will have better luck
  2. #32
    Apr 2005
    San Jose, CA
    If you can still see the title bar for S&T grab it and wiggle the window and it should resize to fit inside its expected region. This can happen the first time you use S&T in RR.
    For the Task Bar issue, go to the RR settings and select "Hide Task bar"
    Chris
  3. #33
    Oct 2005
    Albuquerque, NM
    Quote Originally Posted by blk02si
    Thanks for the kind words. The buttons do sometimes get covered up on the first load, haven’t figured out how to cure it yet, but as HyperSprite said just go up and wiggle the title bar. What I usually do is toggle the “full screen” button twice (upper right corner) and it will be fine until you unload RR and S&T.
    There are a number of functions that are not supported in S&T 2005 so several buttons will not work right. I would upgrade to 2006, it is a much better program that gives visual in route driving directions and voice prompts.
    The problem loading multiple times from the “GPS Window Name” in the RoadRunner GPS setup. Run RRConfig and make sure the name in the window is exactly the same as in the instructions (for 2006 installations). In 2005 the path name is a little different using … Streets and Trips …the word “and” in the path where 2006 uses the “&” sign … Streets & Trips. Change using the “and” version in the GPS Window Name if using 2005
  4. #34
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thank You! It works! Although I still have the ambersand (&) in my title, last night i had typed in -Strets & Trips, Haha Forgot an 'e' and could not see it on my 7" monitor. Awesome This is badass. keep up the good work. Any idea how the other guy got his map black and green? that was nice looking also.
  5. #35
    Oct 2005
    Albuquerque, NM
    That is a new function in S&T2006, not available in 2005
  6. #36
    Constant Bitrate Mattkins99's Avatar
    Mar 2005
    Seattle Area
    ya, for $30 or so for the 2006 version, the new features are well worth it. I can't wait for Mappoint 2006 though.
    Matt Atkins
    Seattle5s | President
    '01 M5 Lemans Blue/two tone black and silver interior
    Factory nav.... for now
    Old Car (almost sold)
    '98 540i-6 blk/blk
    Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
  7. #37
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    no joke...it's all about the Mappoint. can't wait to replace my 04 w/ 06
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  8. #38
    Jul 2005
    Motorcity
    Blog Entries
    1
    Well I got S&T 2006 just because I love that night map. Removed 2005 and installed 2006. Im very glad I updated as 2006 has more features and maps. Updated the RR config and it works PERFECT!!! Thank you again for this skin / S&T Functionality. Ive never tried any other GPS programs but S&T works great for me so I see no reason to use the others. The only thing that still wont work for me is the OSK. No matter what I type into it when i exit the OSK only the last key I pressed will be in the text field where I had my cursor. Can I do anything to fix this or is that still in development?
  9. #39
    May 2005
    Vienna, VA
    The built-in OSK never works consistently with embedded apps. You'll see that same behavior in IE, etc.
  10. #40
    Mar 2005
    Seattle Area
    hmm... wonder if you could get it to work with a sendkey command...
    I have a wireless keyboard/trackball so I've never bothered to try. I'll play with it if I get a chance, but it's probably over my head (I know HTML and SQL... no coding yet, but I can usually read it)
    Matt Atkins
    '98 540i-6 blk/blk
  1. Working skin for MS Streets and Trips embedded in RR
    By HyperSprite in forum RR Skins
    Last Post: 05-02-2007, 12:52 PM
  2. Software Review: Streeets and Trips 2006
    By Mattkins99 in forum The Review Palace
    Last Post: 11-14-2006, 02:47 PM
  3. Streets and Trips 2006 released!!!
    By Mattkins99 in forum Road Runner
    Last Post: 10-20-2005, 05:30 PM
  4. Microsoft Streets & Trips 2006
    By buurin in forum GPS
    Last Post: 10-12-2005, 12:08 AM
  5. Replies: 6
    Last Post: 09-29-2005, 06:50 PM
